1978 - 1996 Big Bronco
Leaf Spring Frame Bracket
Old Dec 27, 2011 | 08:06 PM
pdqtimetrialer's Avatar
pdqtimetrialer
My stepson has a 94 Bronco with a rusted out leaf spring frame bracket. The bracket that has failed is on the passenger side, the rear bracket. Access looks tight because of the gas tank. Is it possible to get to all 4 bolts without removing the tank?
I've done this job on my F150 where there was more space to work.
Old Dec 28, 2011 | 09:03 AM
Edgethis's Avatar
Edgethis
Are they bolted or riveted? Don't have my to check right now. I don't think it'd be too hard.
Old Dec 28, 2011 | 12:14 PM
stuart9534's Avatar
stuart9534
If it is a factory bracket it is riveted in. My favorite way to remove the rivets is drilling out the center, and chiseling off the head, then punching the rivet body through the hole.
The nuts for the new bracket are a little tricky to get to with the fuel tank in there, not hard, but time consuming.
And, you are working around a fuel tank, so be very careful with your choice of tools.
Old Dec 28, 2011 | 03:00 PM
pdqtimetrialer
The bracket is riveted on, so it's the original.
Time is something the boys has. Now whether or not he is willing to invest it to fix his truck is another story....
On my F150 is was tight getting some of the hardware in but manageable.
Thanks all. We'll tackle this project after the 1st of the year.
Old Dec 29, 2011 | 06:25 AM
hey172's Avatar
hey172
I did the rear leaf spring shakles and hangers on my 93 about a year ago with out removing the tank it is a pain but not hard also but my parts from autoandtrucksprings.com
Oh on mine with the tank still on the vehical on both sides there were to bolts i had to run in from the ops side then cut the threads so that they would not hit the springs
Old Dec 29, 2011 | 04:40 PM
roosplash's Avatar
roosplash
I found it easier to grind the head of the rivits flush to the bracket then use a drift to punch it through. Used grade 8 hardware to bolt on a new flip bracket I welded up
rushinriver
Mar 30, 2009 12:35 AM
dennisb56
May 14, 2007 08:14 AM
black460
Nov 7, 2006 08:31 AM
fordtruck88
May 1, 2006 07:48 AM
djjoshuad
25
Dec 1, 2004 11:08 PM
