Sponsored by: Auxito
rear end binds
Old Dec 27, 2011 | 12:15 PM
jrm05261966's Avatar
jrm05261966
rear end binds
I have a 2000 f150 4 wheel drive with a limited slip 3.55 gear rear end. when I back up and turn in two wheel drive no problem , in 4 hi as you turn it needs more rpms to move and on gravel after a short distance the rear end acts like it is locked up until you pull back forward then it's fine. had all new bearings and ring and pinion installed in may ??? any thoughts
Old Dec 27, 2011 | 10:35 PM
steve(ill)'s Avatar
steve(ill)
It may be alright. That just shows your LS unit and 4 x 4 are working. Mine does a similar thing when in 4 x 4 forward . in 2 x 4 everything is o.k. When i shift to 4 x 4 in the driveway, and turn the wheel, its like herding elephants down a path. Dont want to turn at all unless you are in the grass or loose dirt. You got at least 3 of the 4 tires trying to go different speeds and that causes the binding. Try it in the grass.
Cope
Offroad & 4x4
20
Jan 21, 2016 07:46 AM
fxsmit9
1997 - 2003 F150
16
Mar 12, 2012 11:34 PM
preppypyro
Jun 23, 2007 10:49 PM
saltwaterman
Oct 10, 2004 10:43 AM
Trail_Rider
Dec 20, 1999 03:26 PM
