Okay guys. My lovely wife bought me a paint gun kit, an electric da sander for Christmas. So now the work begins! My question is what primer should I use? I am stripping back to Bare metal, I plan on priming the entire truck and setting it all aside and working on one piece at a time. I figure this will take me a few years with what little time I will have. I'm a novice so keep that in mind if there is a primer out there that is easier to spray.
Thanks
I have been using a 2-part epoxy primer from SPI. I have found it to be of excellent quality, and a very reasonable price. Here is a link to their website; Home
A link to their forum; SPI User Forums
And a link to my project, so you can see some of their product in action; https://www.ford-trucks.com/forums/9...build-log.html
I have been using a $50 Harbor Freight hvlp spray gun while spraying the primer. I'm not sure yet whether I will be spraying the paint or farming it out. I still have lots of body work to do before I get to that stage. Good luck with your project.
I use House of Kolors epoxy primers, to each their own but I tend to feel it's best to stay with one brand through the whole thing. Keeps things simple and helps to avoid using paint or clear coat that doesn't work properly with the primer or what's under it.
While you will get good advise on here, especially in the paint forum. I would advise finding your local auto paint supply store. Most deal primarily with body shops and are knowledgeable in the products they sell. They can be very helpful working with you in the price range you choose. An experienced painter that uses one product that he is comfortable with, can order online saving some money, but he knows exactly what he wants. Hopefully your wife bought you a gun that is compatable for your compressor.
Whatever brand you use, it needs to be an epoxy primer. Other primers are porous and will let any moisture through. When you're ready to work the part, you'll have to scuff the epoxy up some for anything to stick (filler, high build primer, paint). I use 80 grit for the scuffing.
You bring up a good point, Carlene. I sandblasted my entire cab down to the bare metal, and I needed to get a primer on it in a hurry so that it wouldn't flash rust on me. BUT I need to do some body work eventually. So a handful of pretty good paint/body people told me to get some self-etching primer on it to begin with, do my body work, THEN use the epoxy. Their reasoning was exactly what you said above about the difficulty in getting things to stick to the epoxy.
Doc brings up a good point. The self etching primer usually contains something like phosphoric acid to etch the metal. It will react with rust to neutralize it...even if it looks like you've sanded to bare metal, there might be rust in the pores of the metal.
An option is to use an acid wash when the metal is sanded bare...then neutralize it...then prime it with a good primer. Everyone on here has recommended a two part epoxy primer...I think they're right. If you have any serious rust problems the products like POR 15, Rust Mort, or Rust Bullet all include some form or acid wash pre-treatment.
I went the overkill route with our 41 - - - sandblasted, Ospho'd (phosphoric acid wash), self-etching primer, a little Evercoat Rage filler (easy to work with), epoxy, then bc/cc. I use POR's Metal Ready (another phosphoric acid) on the smaller parts because of its cost. Ospho does the same thing, you just have to wait longer to do anything with it, like 24 hrs.
If any of the parts are going to sit for any length of time, they really should have epoxy over them. The acid washes & self-etching primers don't work for long term storage or handling without a top coat.
Epoxy. Beware, some etch primers are not designed to have filler applied directly over them.
Also get a GOOD respirator for spraying auto paint products.
Good info in this thread. Thanks. Why is it so hard for the paint/body crowd to agree on anything sometimes? If you ask 10 different people, they very well might give you 10 different answers. It's enough to drive a person nuts sometimes (well....in my case, that drive isn't very far at all).
You have a mixture of people who do it for a living and the hobbiest(me). I've had proffesional work done that wasn't worth a crap either. That's why I paint my own stuff, but won't touch anyone else's. Many different product lines and data sheets to go with each telling you what to do and not do. Staying within one product line makes things a lot easier. At least dealing with a local supplier, I can go back on them if something is not right. And I have had to do that once. They stood behind what they told me, even though they were not aware of the problem at the time. It was a simple thing that a high quality glaze("iceing") could not be shot over with a 2K primer.
Above is all good information, I will add the following that a long time paint man once told me. Make sure you have two guns, one for primer and one for finish. Primer will wear out a gun much quicker the finish paint. Usually what I do is when one project is done, the finish gun becomes my new primer gun.
All of this is good information, there are so many answers because there are so many good products out there. One that was not mentioned was the sprayable polyester filler which can be used on areas that don't need a lot of bodywork to be straight, it sprays like high build primer but (IMHO) sands much easier.
Also use the correct tip for primer and for top coat. Primers have lots of solids and need a larger tip, 1.7 or 1.8. Top coats and clear coats need a smaller tip to get better atomization, somewhere around a 1.2 usually works well. I use Eastwood which I have found to be less expensive and has very good support through email or phone. They have an amazing amount of product and can tell you what is compatible with what.
OFF TOPIC I just want to say I've missed those flashy eyes. Oh ya definately use epoxy primer before anything else.
