Fuel ine Seals
Old Dec 27, 2011 | 06:58 AM
catbird7's Avatar
catbird7
Fuel ine Seals
Does anyone know the part numbers for the rubber seals on the fuel lines? Where the line enters and exits the filter housing as well as where it enters the injection pump. I think there's another one where the return lines intersect on the driverside near the back of the engine. Surely either Ford or International makes a kit for replacing these seals?
Old Dec 27, 2011 | 07:09 AM
kenpobuck's Avatar
kenpobuck
I got mine at the Ford dealer. I can't remember the part#'s but if you go into the parts department and look at the screen with the salesman you can show him the parts you need (that is what I had to do). The 2 seals on the line between the filter header and the ip (5/16") cost me about $6. This type of seal is called a vibro loc I believe and you can also find them in some good hardware stores.
I found this place http://www.intellidog.com/dieselmann/ford.htm He has them as well.
Old Dec 28, 2011 | 07:57 AM
catbird7's Avatar
catbird7
FYI: I found the seals are still available from FORD under the following pn#'s
E3TZ-9C387A
E3TZ-9K260A
I'm picking them up today, I think the price was less than $15.00 for all of them.
Tigerlillyrk
Apr 18, 2018 09:19 PM
SEH43
Sep 14, 2016 12:03 PM
linckeil
Sep 2, 2010 08:14 AM
kenpobuck
Mar 13, 2009 12:44 AM
ghunt
Feb 1, 2008 06:30 AM
