'78 351M question
Old Dec 26, 2011 | 09:42 PM
jgavac's Avatar
jgavac
'78 351M question
What was the stock engine color on a '78 351M? And was the air cleaner painted?
Thanks
Jameson
Old Dec 26, 2011 | 09:51 PM
JB78f150's Avatar
JB78f150
Mine is blue and the air cleaner is galvinized.
Old Dec 26, 2011 | 10:03 PM
devino246's Avatar
devino246
Engine is FORD blue. Make sure its FORD
I painted my trans pan with GM blue when I changed the fluid. I know, it was a cardinal sin, but it's all we had You can see the engine color in this pic:
Old Dec 26, 2011 | 10:11 PM
jgavac's Avatar
jgavac
Ford old blue or ford new blue?
Old Dec 26, 2011 | 10:18 PM
devino246's Avatar
devino246
New. According to Google, the color changed around 66/67
Old Dec 26, 2011 | 11:11 PM
Ken(Ark)'s Avatar
Ken(Ark)
Anybody know the story behind that ?
Everything out of my shop get the true blue old school dark paint .
I started fooling with N series Ford tractors (39-52) and they use red back ground in the ovals with the Ford script . Don't know if I can ever get use to that .
Old Dec 26, 2011 | 11:16 PM
devino246's Avatar
devino246
Maybe NumberDummy will chime in. He could probably write a book about the color change.
Old Dec 27, 2011 | 03:47 PM
jgavac's Avatar
jgavac
Huh because I used 2 cans of Duplicolor "Ford Blue" on one of my 460's, and it looked more along the lines of that gm blue
This was what I got
This was the color I wanted. You can see the manifolds from the other engine on this one, and the difference in color
Jameson
Old Dec 28, 2011 | 09:17 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
Well, I don't know about old or new, but as for my 351s, I always saw the darker blue. I always painted my engines the lighter blue, still supposed to be ford blue, but lighter, I like it better. My experience is the 351 and 400s had the darker blue. Not sure if it is old or new.
Old Dec 28, 2011 | 09:41 PM
ctubutis's Avatar
ctubutis
I have always used DupliColor DE 1606 Ford Dark Blue
Old Dec 28, 2011 | 10:23 PM
smokeyb97's Avatar
smokeyb97
Thanks
Jameson
http://cometeastcarclub.org/PDF_Files/enginecolor.pdf
If it is blue, it is power by Ford.
For many years prior to 1966, as we have seen, Ford engines were color-keyed to specific applications and carlines. Starting in 1966, this practice changed. All engine now were painted Ford Corporate Blue. Instead of color-keyed valve covers and air cleaners, the entire engine would be Ford Corporate Blue, like the Ford Blue Oval and the Ford Blue offset dealer signs popping up in 1966 at Ford dealerships. Ford's message for 1966 and beyond was simple--if it is blue, it is power by Ford.
As in earlier years, Ford continued to paint the valve covers separate from the engines. Engine long-blocks, which included block, intake manifold, heads, and oil pan, were all painted Ford Blue. Valve covers were installed toward the end of engine assembly using natural metal bolts with integral lock washers. We've learned through observation and conversation with restorers that Duplicolor's Dark Ford Blue (1606) is an accepted color for '66 and later Ford engine restorations. An alternative, when Duplicolor isn't available, is Krylon's Dark FordBlue, which is also the correct shade of dark blue. Plastikote is another paint brand, Royal Blue (1134) an acceptable color for '66 and later.
Old Dec 28, 2011 | 10:34 PM
jgavac's Avatar
jgavac
Interesting to know. Thanks
Old Dec 29, 2011 | 09:11 AM
74 F350 SCS's Avatar
74 F350 SCS
That is interesting to know and thanks for the info. I know that in my garage, I have a can of "old Ford blue", "Dark Ford Blue", and I think just "Ford Blue". I can never get it right of which blue went with what year?
Number4
Oct 21, 2018 01:45 PM
Matt1966
Jul 20, 2017 02:15 PM
74f100sc
Jul 15, 2016 09:33 PM
fordophile
Sep 22, 2008 07:07 PM
79 posi
Mar 27, 2006 06:51 PM
