fluid in spark plug well #3 help!
There are seals at the area of each plug hole and the cylinder head and to fix your leak you will have to remove the cover and install new seals. A bit of a PITA and not always neccessary unless the oil shorts the plug(s) causing a miss. You could just vacuum the oil out before removing the plug to keep it out of the engine. If you keep the truck you will have to replace the seals eventually.
Thank you guys! I thought the fluid smelled like gas. I'm hoping the previous owner spilled some while relieving the fuel pressure. I'm gonna take your advice and vac it out. then wait to see if it comes back. I'll check for that pesky leaking heater hose that always leaks in their too. Thanks again. I'll let you know how it turns out.
frank f150
1997-2006 Expedition & Navigator
12-11-2010 12:16 PM
montster
07-13-2003 05:50 PM
