front diff fluid
Old Jul 10, 2003 | 07:53 AM
montster's Avatar
montster
front diff fluid
hi I am putting H6 's in my 83 bronco and wondered if there is any easy way to change the fluid in the front diff. I plan on mudding alot with the truck and would like to be able to change the oil in there. a buddy said to just loosen the casing bolts and let it leak and refill, but does that mean I need a special gasket ect.? any help would be appreciated.
Old Jul 13, 2003 | 01:33 PM
c_rossman's Avatar
c_rossman
front diff fluid
I would just pump it out thru the fill plug. I have seen an article on here where to drill and tap for a drain plug.
Old Jul 13, 2003 | 05:50 PM
steve83's Avatar
steve83
front diff fluid
If you let it leak and DON'T reseal it properly with silicone, it WILL continue to leak. But I mudded mine for several years in Louisiana's gumbo and drove back & forth across the country for a few years, and when I finally drained mine, the oil looked new. As long as you keep the vent hose connected and routed up above the soup, you shouldn't have to worry about it.
