68 4x4 suspension
Old Apr 17, 2003 | 01:38 AM
99banshee's Avatar
99banshee
68 4x4 suspension
I am new here so bear with me if this is common knowlege. I just bought a 68 f250 with a 390, manual, and 8 lug gear and wanted to know if the 4 inch blocks in the back are factory or a lift. They appear to be factory because of the bumpstop platforms on the side. How high did these come cause it's clearing 35's. Also do you know a good vin number web site. Highboy?
Old Apr 17, 2003 | 03:13 AM
pjm66f100's Avatar
pjm66f100
68 4x4 suspension
Yep, those are factory blocks.
It is a "Highboy", they will clear 35's no problems.
I have been told that with the 4" Skyjacker lift, you can fit 40's.
----Patrick
Old Apr 17, 2003 | 01:25 PM
Mil1ion's Avatar
Mil1ion
68 4x4 suspension
You can just post the rating plate info here and we'll de-code it for you.
The VIN # doesn't really tell you much.
only the Chassis,Engine,Plant,Build number
Old Apr 17, 2003 | 01:53 PM
99banshee's Avatar
99banshee
68 4x4 suspension
thanks, but what and were is the rating plate
Old Apr 17, 2003 | 02:15 PM
BB's Avatar
BB
68 4x4 suspension
Hi 99banshee and welcome to FTE!
Don’t know of a good VIN decoder for the ’68 – ’69 trucks.
The rating plate is on the driver’s door by the latch mech.
We’ll see ‘ya around, enjoy the site!
Barry
Old Apr 17, 2003 | 11:18 PM
99banshee's Avatar
99banshee
68 4x4 suspension
my doors are not the originals.
Old Apr 20, 2003 | 10:55 AM
fatdaddy's Avatar
fatdaddy
68 4x4 suspension
measure the diameter on the locking hubs of your front axle. If they are 4 1\2 inches or so ...you probably have the closed-knuckle, heavy duty, dana 44 series front axle. In any case, your rear axle should be the full-floating , dana 60 series. You should have the removable , exterior axle . with the 10 small bolts , i believe. fd
Old Apr 20, 2003 | 01:20 PM
Mil1ion's Avatar
Mil1ion
68 4x4 suspension
Banshee,.
Rating plate is Ford's terminology.
I prefer to call it the Data Plate.
Early 70's plates were in the front door jamb instead of on the door.
Old Apr 20, 2003 | 03:39 PM
99banshee's Avatar
99banshee
68 4x4 suspension
the data plate in on the door, but the door isn't original so it doesn't do me any good. the front end is a closed knuckle and the rear end is full floating. Is there any way to put disc brakes on that front for not to much $. Also did any of these trucks come with power steering that I can use to convert mine. I'll have to snoop around the junk yards. We should get a group purchase going through skyjacker
beez9830
Feb 19, 2015 09:02 PM
tfmech
Jul 14, 2012 11:54 AM
68-F250-4x4
Jan 4, 2008 09:43 AM
blue68f100
Aug 20, 2007 03:50 PM
68shortbedmo
Mar 19, 2007 08:34 AM
