average EGT?
Old Dec 26, 2011 | 05:46 AM
highteckredneck's Avatar
highteckredneck
average EGT?
i have been monetering my egt's and they are around 800 degrees after the turbo when crusing at 65mph. question is what is the safe zone? i hear that high EGT temp are the biggest 6.0 killer. this is my first diesel truck so i want it to run as long as possible since repairs are alot more expensive than my ol F150.
Old Dec 26, 2011 | 05:55 AM
2006lariat's Avatar
2006lariat
You are running a Tuner, (Bank's if I recall) I would move your EGT probe to the drivers side manifold. It will be WAY more accurate, (In relation to what your turbo is seeing temp wise) and is easy to do/get at. I put my probe in, in about 5 minutes. 800* after turbo is probably (this is a guess) 1000-1100*f before turbo. Perfectly safe. You need to worry, at anything holding at or over 1300*f BEFORE TURBO. Your turbo can spike at them level's and be fine though.
Old Dec 26, 2011 | 02:35 PM
Dieselpop's Avatar
Dieselpop
You need to pull the pyro and plug the hole and install in the right place to get the right temp readings plus if you turn off your truck to quick you can coke your bearings in the turbo or if you get it to hot. When pulling i try and not to get over 1350* i will back off to 1300* but you need to get the readings from the right spot.
Coking, turbo bearing lubrication and engine oil viscosity
You should use a 5w40 Syn oil this will help because a Syn oil will take the heat better than Dino plus your injectors will like it.
This is a must if you pull heavy even if you do not, need for cool down 350*-360* before you turn the key off.
After drilling it out i used a magnet with a paper clip with a L shape on the end clip taped to the magnet run in the hole to remove any steel then tap the hole going only half way with the tap so you do not over size the hole, do not use grease. (the steel is soft so be carefull) Take is slow.
3-Gauge Install Pictures
pop
Old Dec 26, 2011 | 06:58 PM
highteckredneck
yes i have the banks but i kept getting told to take it off. i am thinking of just running some a-piller gauges ( EGT, BOOST, ETC.) just wanted to know the safe zone. also i try to let the truck idle for about 5 min or so just to let the turbo cool down before i turn the truck off.
Old Dec 26, 2011 | 07:17 PM
smokersteve's Avatar
smokersteve
under 400*F EGT is a good temp to turn the truck off.
Edge insight, insight cs, insight cts, scan gauge 1 and 2 are highly used for monitoring the 6.0L.
Old Dec 26, 2011 | 07:39 PM
dakotajeep's Avatar
dakotajeep
I am running the Insight. So far no issues related to the Insight.
I would also recommend putting your thermocouple preturbo since the vast majority of people have it there...makes it easier to compare with others.
Thad
Old Dec 26, 2011 | 08:00 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
30 mph = 400-600F
60 mph = 500-750F depending on grade
I've seen 1400F on short bursts before. It'll get there very quickly with my SRL tune
Old Dec 26, 2011 | 09:23 PM
AJB201's Avatar
AJB201
I run a quadzilla module and have a bullydog watchdog. My probe is on the drivers side near the manifold. At 65mph I run about 675 degrees.
Old Dec 26, 2011 | 09:58 PM
dakotajeep's Avatar
dakotajeep
I don't think 800F is too bad at 65 mph. You just have to remember that there are so many variables that can cause your numbers to be higher or lower.
This evening I had temps steady around 925ish while driving at 70 mph. Had a killer headwind!!!
Thad
Old Dec 26, 2011 | 11:33 PM
brickie's Avatar
brickie
IMHO 800* cruising post turbo is way too hot,that would be about 1100 pre turbo on the flat at 65mph.I run about 700-800 on both mine at 65.
Old Dec 26, 2011 | 11:35 PM
smokersteve
It depends on the tuning, eng set up, and driving conditions(this includes altitude).
wolfrace
Apr 15, 2010 10:30 PM
mudmaker
19
Nov 23, 2007 12:58 PM
raptor131
Jul 24, 2006 05:21 PM
Rodslinger1
Apr 22, 2005 08:32 AM
smokin redneck
33
Nov 22, 2004 08:17 AM
