Sponsored by: Real Truck
5.4 cummins conversion
Old Dec 28, 2011 | 11:08 PM
  #31
dkf's Avatar
dkf
Regear the truck to at least 4.56s, add a tuner with a custom tune and go from there. Still not enough power? Get your hands on a used intercooled supercharger setup off a lightning and get the truck tuned for it. Running 4 or 5 lbs of boost will give you a very noticeable increase in power and not stress the stock bottom end too much. Or pick up a good used PI 6.8l with harness and pcm and put it in your truck. Swapping a 5.9l into your current truck will be a lot more work than you think.
Old Dec 28, 2011 | 11:12 PM
  #32
whitechocolatefrogs's Avatar
whitechocolatefrogs
Thanks for the info. I was wondering about the stress on the bottom end, just don't overdo it with the boost. I don't really like the 6.8l that much, just a personal preferance.
Old Dec 29, 2011 | 08:06 AM
  #33
xmontex4's Avatar
xmontex4
Does the lighting supercharger bolt right up with no modification needed other than tuning?
Old Dec 29, 2011 | 12:51 PM
  #34
SuperDutyScaler's Avatar
SuperDutyScaler
no it needs wireing swapped out and changed, intake etc. its not a bolt on mod at all.
Theo11040
Sep 9, 2016 08:46 PM
SLOPhil
Aug 24, 2014 09:48 PM
ArrizX
Dec 13, 2011 12:14 PM
simptek
Modular V8 (4.6L, 5.4L)
Feb 6, 2009 01:59 PM
