'75 Highboy crossover steering
Old Dec 24, 2011 | 10:10 PM
thatK30guy's Avatar
thatK30guy
Which gearbox will I need to employ for this?
I'm guessing one of the following:
'78-'79 F250
'76-'79 F150
2wd Ford box
Truck has a swapped in Dana 60 front and ORD passenger side crossover steering arm.
I do not want to use any GM or Dodge Saginaw box. I'm too tired to figure out which box above will work for crossover, so any suggestions, thanks in advance.
Old Dec 24, 2011 | 10:11 PM
thatK30guy's Avatar
thatK30guy
Forgot to add that I've got a Superlift #1104 drop pitman arm to use also. Truck is sitting on 4" Skyjacker front and rear springs.
I prefer the pitman arm to point to the rear when its fastened at the gearbox.
Old Dec 24, 2011 | 10:32 PM
74ford4x4's Avatar
74ford4x4
I know the 78 79 steering box will work, I think the 2 wheel drive box will work to, someone smarter than me will correct me if Im wrong.
Old Dec 25, 2011 | 12:58 AM
ChaseTruck754's Avatar
ChaseTruck754
I wouldn't use the 2wd box. Someone did that on my '74, 4wd crew cab and I had to clean up that hacked up mess! The leaf would hit the end of the sector shaft before the suspension got anywhere near hitting the bump stop...
Here's a few pics of what came on the truck when I bought it & how I replaced the hack job with a saginaw box off a dodge & a bit of the dodge frame.
A saginaw box off a Chevy or Dodge is a GREAT way to go on this. Keep in mind there are different configurations for the boxes - meaning some mount inside the frame, some outside, some have the pitman arm swing opposite the way you turn the wheel & some turn with the wheel. Look at all this before you just buy a box.
cut this junk off
and replaced with some acceptable work...
Old Dec 25, 2011 | 06:44 AM
co425's Avatar
co425
I'm using the same f150 box as above but it's spaced inward about 2" further. It clears the sector just fine. It's also on a heavy duty spacer that is completly removable back to stock.
Old Dec 25, 2011 | 09:30 AM
Blackfoot Big Block's Avatar
Blackfoot Big Block
I'll second what Chase said with respect to the Ford 2wd box.
The '78-'79 F-250 (and '79 F-350) 4wd boxes use four bolts to mount them to the frame. I believe the F-150 box uses three bolts.
I had the 2wd set up and ran it for several years. I think it's much better than having manual steering and it's probably better than the leak prone factory power assist system. However it isn't that great. I found a '78-'79 F-250 box and will run that.
I also own a 1986 Blazer 4wd and that has the stock Saginaw steering box. The Chevrolet frame is different than the Ford in that the Ford frame rails are straight. The Chevrolet frames bent inward quite a bit in the area around the steering box, so even though the steering box mounts outside the frame it doesn't protrude nearly as much, and the angle of the steering shaft to the box is also not as pronounced.
I would also mention that the Chevrolet frames are notorious for cracking in the area around where the steering box bolts. There are aftermarket "beef up" plates available to reinforce this area.
Old Dec 25, 2011 | 01:23 PM
montana_highboy's Avatar
montana_highboy
X3 on the 78/79 4WD box.
F-ONE
Aug 19, 2019 11:24 AM
WeeksJerseys
Oct 14, 2015 09:03 AM
fordf348
May 20, 2014 05:14 PM
crazy96863
Mar 2, 2012 10:31 AM
monstergarage87
Dec 30, 2008 08:36 PM
