Removing Overloads
Old Dec 26, 2011 | 04:04 PM
Blue and White's Avatar
Blue and White
You should be fine up to 2000 lbs or so with the standard springs if the load is reasonably distributed. You can go more it will just drag its tail. I think the overloads are helpful in the 2000-3000+ lb load range.
Old Dec 26, 2011 | 07:10 PM
jgavac's Avatar
jgavac
Ok thanks for the help everyone
Jameson
Old Dec 26, 2011 | 07:54 PM
meborder's Avatar
meborder
the light duty helwigs claim 1000lbs extra, the heavier ones claim 2500lbs extra. you would have to have more than a ton in the box to really "need" them.
as for removing them, i'd consider trying to just remove the u bolts at the ends of the over loads and leave the leafs attached to the axle. this would give you the option to hook them back up if you thought you were going to need them. and give you the chance to decide if it is worth messing with.
it will ride better unloaded with out them, but it may ride better loaded with them, especially if it is loaded heavy.
this summer i had 7500 lbs on the hitch plus 1100 in the bed and it actually rode pretty nice. but empty, it will make your kidneys hurt.
Bluebronco85
28
Mar 1, 2019 11:50 AM
golfmedik
Jun 3, 2016 07:02 PM
SaddleBronc
57
Feb 21, 2014 05:43 PM
Rico47635
Nov 1, 2011 07:36 AM
Lakotas53
Jun 23, 2008 09:16 AM
