Defroster vent vacuum
Old Dec 22, 2011 | 01:41 PM
949803's Avatar
949803
I have noticed air from the blower comes out the vents but will not come out the defroster windshield vents. I dropped the glovebox and see where a vacuum cylender has linkage that has come loose from a lever. When I rotate this plastic lever, the air changes from the dash vents to the windshield defroster vents. This cylender and plastic lever are near the center of the vehicle dash (below the radio). Does anyone have a picture or can describe what this union is supposed to look like. Does not appear to be broken.
Thank You 2003 Ford Explorer XLT 4.0Liter
Old Dec 22, 2011 | 07:13 PM
rrgone's Avatar
rrgone
Send me a PM with your email address and I'll send you a PDF file from FSM that shows the defrost door/vacuum motor connection.
FWIW I have seen several home-made repairs for HVAC doors to vacuum motor connections. It is possible to just tie wrap them together to make a repair.
Old Dec 23, 2011 | 07:28 AM
949803's Avatar
949803
Thank You,
Daniel
bluemax03@gmail.com
Old Dec 23, 2011 | 08:39 AM
steve(ill)'s Avatar
steve(ill)
If you have trouble with access and dont want to disassemble any further, just tie wire or put something in the door to pull it open or hold in mid stroke. NOthing wrong with having some air to defrost and some to vents or floor all the time.
Old Dec 23, 2011 | 08:42 AM
steve(ill)'s Avatar
steve(ill)
here is an air flow diagram.. default is for defrost door to be open when motor off, or no vacuum.
https://www.ford-trucks.com/forums/9...-please-2.html
bunruh
Nov 23, 2022 11:46 AM
pcdocta
43
Mar 19, 2017 04:16 PM
borcht warrior
Jun 20, 2012 12:40 PM
Flyn66dtmn
Dec 7, 2011 08:32 AM
MSG
1983 - 2012 Ranger & B-Series
May 12, 2003 07:30 PM
