Foot heat problems
Old Dec 22, 2011 | 08:43 AM
PMarch's Avatar
PMarch
Foot heat problems
Hi Folks..
I have searched but not found something exactly like mine.
I have a Sport Trac 2007 xlt
Manual control for heat and AC
Here is my problem.
If I put heat Full BLast on feet only. I get nothing.
if I lower the heat setting a bit. I get a little coming out on the feet
if I put full blast on defrost and feet. I get nothing unless I lower heat setting and I get a little bit.
Its all weird.. some advice would be greatly appreciated.
Main thing I dont get enough heat on the feet and winter is coming and wife is already whinning
Thanks
Paul
Old Dec 22, 2011 | 08:55 AM
caseys's Avatar
caseys
xxxxxxxxxx
Old Dec 22, 2011 | 09:25 AM
PMarch's Avatar
PMarch
awesome....
Thanks
Paul
Old Dec 22, 2011 | 11:10 AM
caseys's Avatar
caseys
xxxxxxxxxx
Old Dec 22, 2011 | 11:26 AM
PMarch's Avatar
PMarch
nice.. I went to check today and could not figure it out..
With these instructions.. I might have better luck..
I am not mechanically incline
Old Mar 2, 2021 | 10:07 PM
Karlow's Avatar
Karlow
That was fun,
Now is how to test it.
Get a ladder and some plywood. I used foam blocks in place of the plywood.
You need to be able to climb on top of the engine and reach around the turbo and the down pipe with the engine running.
With the engine cold set up the ladder and your wood. Start her up climb on top of the engine and reach around the turbo and that down pipe. If it's leaking you should be able to feel it. You need to do this before it gets to hot to feel around there. It took me five tries to get the turbo installed correctly.
Shovelhead 93
2004 - 2008 F150
20
Sep 16, 2012 10:17 AM
Diesel cat
Dec 4, 2011 10:05 PM
oldfordcoupe
Mississippi Chapter
Jul 13, 2010 07:21 PM
Scolesy8
Apr 17, 2008 04:09 AM
