firewall tag
Old Dec 22, 2011 | 08:10 AM
vinnieferg's Avatar
vinnieferg
firewall tag
I just noticed a tag wired to the firewall of my 65 f100
what info is on it..I'm green at posting and would like to attatch a picture of it,but not sure how to..?? Help
I do have a picture on my album though..~ Vin
Old Dec 22, 2011 | 09:58 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by vinnieferg
I just noticed a tag wired to the firewall of my 65 F100.
This is a buck tag .. only used by assembly line workers. The codes stamped on it...cannot be decoded.
These codes were only used by these workers to make sure the correct parts were installed on the truck.
Your album photo of Warranty Plate: F10JL588742 / 115 / A / F101 / 581 / A / 09 / 4200 / 129 / 4000 / 21
F10 = F100 2WD
J = 240 1V I-6.
L = Michigan Truck Assembly Plant.
588742 = 1965, assembled September 1964.
115" Wheelbase.
A = Raven Black.
F101 = F100 2WD, 4,200 lbs. GVWR
581: 5 = Red Crush Vinyl & Red Wicker Pattern Vinyl // 81 = 81A Standard Cab.
A = Ford type 3.03 3 Speed Manual all Syncromesh Transmission.
09 = Ford 9" Rear Axle / 3,70-1 / non Limited Slip / 3,300 lb. Rear Axle Capacity.
4,200 lbs. Gross Vehicle Weight Rating.
129 net HP @ 4,000 RPM
21 = Atlanta GA Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Dec 22, 2011 | 03:55 PM
camperspecial65's Avatar
camperspecial65
I cant see pic in album...small square box w/an X in it...
- cs65
Old Dec 23, 2011 | 01:03 PM
vinnieferg's Avatar
vinnieferg
pictures
- cs65
Check my Garage for pics.
Old Dec 24, 2011 | 03:47 PM
camperspecial65
I found it...interesting...have you had your door tag decoded ??? what other documents have you found in/on the truck ??? Build sheet, carb tag, engine tag, rear end tag, seat buck tag(attached to seat frame..seen when seat folded fwd)
PM or email info...reason i ask is I found a build sheet among other things in a truck yesterday...Im always trying to figure out some of the codes and such on our trucks...
Nice truck you have...black isnt a common color to see on these trucks nowadays in original condition.
- cs65
Old Dec 24, 2011 | 04:04 PM
NumberDummy
I found it...interesting...have you had your door tag Warranty Plate decoded ???
I decoded it two days ago, see post #2.
Old Dec 25, 2011 | 06:19 AM
vinnieferg's Avatar
vinnieferg
Tags
Yes has been decoded by #Dummy ( but think his handle is misleading lol)
I will look for the other tags and for a build sheet, Carb tag is missing though.
This is all making me more excited to get at this truck.
Thanks guys for all the help and interest!!
~~~V~~
p.s. the 09 code you say is a non limited slip..does that mean it is what I call positraction rear end????
Old Dec 25, 2011 | 10:26 AM
NumberDummy
The 09 code you say is a non limited slip..does that mean it is what I call positraction rear end????
No, posi and positraction are GM terms, Ford calls their version Limited Slip.
Non Limited Slip means no Limited Slip.
Old Dec 25, 2011 | 11:07 AM
vinnieferg's Avatar
vinnieferg
HAHA Gotcha...need to learn new verbage....... :-)
Old Dec 25, 2011 | 11:39 AM
Customcab's Avatar
Customcab
Another common place to find a buck tag in behind the tailight assembly. As mention they seem to place them in odd places so the public wouldn't seem so confuse I quess.
1965GTFB
Apr 24, 2015 03:13 PM
Dbass1292
Aug 23, 2014 04:07 PM
diesldoct
Apr 25, 2014 12:05 PM
1965GTFB
Jan 21, 2011 01:13 AM
Shorty 66
Jun 8, 2008 11:14 AM
