1994 7.3l idi f250 Excessive white smoke?
#47
#48
#51
Thats what im thinking, never thought about it until too late. When i would run it, it would run worse, but when i went back to #2 it was fine. However it was progressively getting worse, and now that im back on #2 again, its better, but not better enough, not by a long shot. Really a bummer as that pump and injectors ran pretty good. Now since i have the turbo on there, having other "odd" things happen, but they might not be bad.
#52
94 7.3idi, here is a trhead that may be helpful.
https://www.ford-trucks.com/forums/9...ith-my-ip.html
I personall didn't have to pull the front apart to find the mark but it did take some doing.
#53
#55
Hey guys I know its been awhile but I got my new injectors in and everything put back together and now I'm getting fuel past my filter but not past my injector pump. The fuel shut off solenoid and timing advance both light up with a test light and I can hear them click on when the key is on but when I go to bleed the lines I'm not getting a drop of fuel out of the lines. I'm really hoping its not a bad injector pump... again I'm getting sick of pulling this all apart just to find another problem. Can anyone help me with getting fuel to my injectors?
#58
#59
I know this is old, but mines doing the same thing unless i keep it plugged up and it's not as bad but mine smokes worse than yours did on cold starts. The injectors fixed yours? I'm thinking I have the same problems. I put new glow plugs return lines and o rings and caps no leaks now but massive smoke.
#60
I scanned the replies and did not see this possible answer or a solution, yet. Have you checked your return line check valve? There is a similar post and problem on youtube that goes through the repair with almost identical problem.
Edit: LOL, Never mind...., post # 58 says it all. How did I miss that?
Last edited by Dieselamour; 05-29-2016 at 08:01 PM. Reason: added information due to missed post.
