ABS Light on (update 12/22/11)
Old Dec 21, 2011 | 12:44 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
My ABS Light is on after a complete rear brake job and rear diff lube change. Any ideas? New Rotors, Pads,and rebuilt Park Brake.
Old Dec 21, 2011 | 12:53 PM
Shake-N-Bake's Avatar
Shake-N-Bake
My Vehicle Speed Sensor (VSS) failed immediately after my first diff fluid change. $38 for a new sensor and I was back on the road. I am due for another fluid change...I wonder if the same thing will happen again.
Old Dec 21, 2011 | 01:10 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Where did you get your VSS at? Ford or a parts store like AZ, Advance, Napa ?
Old Dec 21, 2011 | 01:15 PM
PaysonPSD's Avatar
PaysonPSD
Have you removed and cleaned the VSS?
VSS through Ed is $23.92. Look under Brakes > Anti-Lock Brakes > Rear Sensor.
Ask your local Ford dealer if they will price match.
Old Dec 21, 2011 | 01:24 PM
Nsaan's Avatar
Nsaan
When my VSS died my speedo would not work until i had driven over 5-10 mph like from a stop, then it would spring up and show right, and my ABS light would come on. I don't remember the Ford one I got being much more then 30 bucks. It was almost 2 years ago, no problems since.
Old Dec 21, 2011 | 01:26 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
No not yet Just got the wheels back on and went to pull out of the shop and saw that it was on was go to go for a test drive but can't get my truck to pull the wet grassy noll out of my shop so i'm stuck again till the rain stops. Need too put in a gravel drive down to my shop.
Old Dec 21, 2011 | 04:46 PM
TchTchr's Avatar
TchTchr
If you can, have it scanned. A code will tell you which sensor it is. There are two in the front also.
Old Dec 21, 2011 | 08:07 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
OK got back from town and went out and hooked AE up and got these codes.
1; C1233 Wheel Speed Sensor LF Signal Missing-ABS
2; C1234 Wheel Speed Sensor RF Signal Missing-ABS
How could this be I didn't mess with the front brakes
What do I need to do to fix this?
Old Dec 21, 2011 | 08:30 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Could I of damaged something when I pushed the pistons for the rear calipers in?
Old Dec 21, 2011 | 08:33 PM
Franko72's Avatar
Franko72
Molon Labe
I wouldn't think so, but I haven't done my rears yet, so I'm not even sure If I have rear ABS?
Was there any wheel sensors on the rears Rich?
Old Dec 21, 2011 | 08:49 PM
nlemerise's Avatar
nlemerise
Isn't this a front end ABS problem?
Old Dec 21, 2011 | 09:02 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
No sensors on the rear wheels but to my understanding the VSS is used for the ABS sensor for the rear brakes.
that's what the codes are for but they weren't there before my brake job on the rear brakes. I didn't touch the front.
Old Dec 21, 2011 | 09:06 PM
nlemerise's Avatar
nlemerise
I get it, I think. Without an operating VSS, the front ABS have no "knowledge" of rear wheel velocity. Is that what you are thinking?
Old Dec 21, 2011 | 09:11 PM
Franko72's Avatar
Franko72
Molon Labe
I had my rear VSS go bad on my truck, changed it out and my ABS light went out, but that was before I got AE, so I never pulled codes.
I can unplug my VSS and see what codes I get tomorrow morning. I'm curious now?
Old Dec 21, 2011 | 09:13 PM
Franko72's Avatar
Franko72
Molon Labe
I was thinking along those lines, maybe a loop system, a bad sensor and the others get a mixed/no signal.
