Question,i put about 5 oz of diesel kleen in each tk evertime i fill up,seems to help the mpg a little,is there any problem with using it this often,just wondering.
jim
I have poured Diesel Kleen into the fuel bowl undiluted before to try and clean up a bad set of injectors. It doesn't run the best, but it didn't seem to make anything any worse. I have heard from several guys that they top off the fuel bowl with the stuff undiluted after they change the fuel filter.
I'm running the Redline additive on one of my tanks and had recently wondered if ashless two-stroke oil would mix happily with the diesel/additive, et.
