Modular V10 (6.8l)
stuck in 4low please help
Old Dec 20, 2011 | 05:00 PM
alexs223's Avatar
alexs223
Question stuck in 4low please help
I've got a 99 F350 4x4 V10 that is stuck in 4Low. It was never put in 4low. Started the truck and the transfer case automatically locked it in. It is the electronic shift on the fly. What could be the issue and how do I fix it?
I've checked fuses, not sure where the relays for the shift of the fly system are, so if anyone knows where their located I'd appreciate it. According to the fuse chart they are #40, but there is no #40 location labeled under the hood.
Tried putting it into 4low, 4high, then back into 2 wheel and no luck, still stuck in 4low.
Help!!!
Old Dec 20, 2011 | 06:39 PM
Fordfanatic4life's Avatar
Fordfanatic4life
you are stopped in neutral with ur foot on the brake right ???
it wont come out of 4LOW otherwise.
Old Dec 20, 2011 | 08:30 PM
alexs223's Avatar
alexs223
It wont come out of 4low at all. I had it in neutral and foot on brake and it will not shift at all. It has electronic shift on the fly. The shift **** on the dash is on 2wd and the transfer is in 4low.
I ended up taking the shift motor out of the transfer and shifting it manually back into 2wd.
I tried shifting into 4low/2wd/4high with the **** on the dash with the motor out to see if it would respond and there was no response.
Dantaylor069
Aug 11, 2019 03:43 PM
clintbonnie
Oct 6, 2014 02:42 PM
oct7brian
May 2, 2009 11:27 PM
shawn_gumby
1997 - 2003 F150
Nov 12, 2006 08:47 PM
subbie
1983 - 2012 Ranger & B-Series
Jan 19, 2004 06:05 PM
