Stuck in 4low
Old Aug 9, 2019 | 03:22 PM
Dantaylor069's Avatar
Dantaylor069
Stuck in 4low
Is there a fuse I can pull to disable the 4 low option in my truck ty ahead of time it's been stuck in 4 low for 3 days now
Old Aug 9, 2019 | 04:14 PM
00t444e's Avatar
00t444e
The shift motor needs power to shift it out of 4 low so pulling a fuse won't do anything. To shift in and out of 4x4 low you have to be in neural with your foot on the brake. If that doesn't work you can pull the shift motor off of the transfer case and use a wrench or some pliers to shift it back into 2wd, until you have time to fix the problem.
Old Aug 9, 2019 | 04:19 PM
Dantaylor069
I'm at the dealership in now getting a new motorty for your help
Old Aug 9, 2019 | 07:51 PM
Carlosfj80's Avatar
Carlosfj80
I had that same problem, my degas was overflowing and shorting out my shift motor. Easy job, maybe an hour and $190 for the better motor, $125 for the cardone.
Old Aug 11, 2019 | 03:43 PM
Striderwv's Avatar
Striderwv
Did you check the fluid level? I was once at a gas station where this guys car couldn't move. Checked the fluid and it was off the stick. Filled it up with tranny fluid and off it went. Just a thought.
