I've got a 99 F350 4x4 V10 that is stuck in 4Low. It was never put in 4low. Started the truck and the transfer case automatically locked it in. It is the electronic shift on the fly. What could be the issue and how do I fix it?
I've checked fuses, not sure where the relays for the shift of the fly system are, so if anyone knows where their located I'd appreciate it. According to the fuse chart they are #40, but there is no #40 location labeled under the hood.
Tried putting it into 4low, 4high, then back into 2 wheel and no luck, still stuck in 4low.
