Camshaft eccentric on a 360...
Old Dec 20, 2011 | 01:16 PM
DKW 86's Avatar
DKW 86
There is no way the canshaft eccentric on an FE should be free to turn is there? I rebuilt many Windsors over the years, but i have very little experience on the FEs.
i was replacing a leaking fuel pump today and was having issues getting it realigned and sitting in the hole properly. I reached into the timing chain cover to feel where the eccentric is.I
1) the chain feels awful loose.
2) the eccentric can easily be turned with my finger tips.
On the upside, i was going to partially teardown the engine to fix a rear main leak. Now it looks like the front end has to come off too. I am seriously considering a cam swap at present as well while i am in there.
I dont want to waste anymore cash on the motor if i dont have to tho. Was loking at replacing it with a 302 or 351W later.
Opinions? Comments on eccentric being loose?
Old Dec 20, 2011 | 02:12 PM
montana_highboy's Avatar
montana_highboy
Originally Posted by DKW 86
the eccentric can easily be turned with my finger tips. Comments on eccentric being loose?
If it's the 2 piece eccentric, which i assume it is, the outer ring should turn freely.
Old Dec 20, 2011 | 02:33 PM
Sleepy445FE's Avatar
Sleepy445FE
^^Yep.
If you don't plan on swapping in a 390 rotating assembly somewhere down the line, then I wouldn't bother with a cam swap. You won't see the gains you expect out of the 360. CR is just too low with the piston so far down the hole. The 390 rotating assembly can be found pretty cheap though, as little as $200 for crank/rods/pistons ready to run.
Old Dec 20, 2011 | 02:41 PM
DKW 86's Avatar
DKW 86
The eccentric is two piece? The diagrams i have found so far only show a one piece. If that is correct, then i can go ahead hen huh?
Old Dec 20, 2011 | 02:58 PM
montana_highboy
That's the earlier style, Ford went to a 2pc. eccentric in 72/73?, i know my '69 FE had a 1pc. eccentric when i tore it down.
Old Dec 20, 2011 | 03:03 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Yup, The eccentric is two piece. The outer ring is free to rotate on the inner eccentric. This was to reduce wear on the pump arm and eccentric itself. This allowed the outer ring to do more "pushing" on the pump arm rather than rotating and rubbing wear on the arm.
Old Dec 20, 2011 | 03:51 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
That's the earlier style, Ford went to a 2pc. eccentric in 1974.
C3AZ-6287-A (replaced B8A-6287-A) .. FE Eccentric ~ 1958/73.
D5TZ-6287-A .. FE Inner Eccentric ~ 1974/76.
D5AZ-6287-C .. FE Outer Eccentric ~ 1974
D0AZ-6287-B .. FE Outer Eccentric ~ 1975/76
But...who knows what year the engine in the truck is...now? Is it the original, or is it from...lawd only knows...some other year?
Peeps tend to swap parts around, so the only way to know...for sure...is to take a look-see.
Old Dec 20, 2011 | 05:12 PM
Rogue_Wulff's Avatar
Rogue_Wulff
The OP's sig states the truck is a 76, so the 2 piece style should be in place.
Old Dec 20, 2011 | 05:27 PM
NumberDummy
Yes...if the engine is original...to the 1976.
Old Dec 21, 2011 | 09:51 AM
DKW 86's Avatar
DKW 86
Gentlemen, thanks a bunch. i have plenty of experience with other Ford motors but not the FE series. And the info on the eccentric ring i was not finding doing google image searches. Love this pplace. Just saved me a bunch of time and heartache.
Old Feb 27, 2021 | 12:10 AM
Danyal Naseem Albert's Avatar
You answer really helped me. So thank you for that first of all. Second question. Do you put pin too
This is the kit I got. Any of these pin will go in there ?
And this is how I have it without pin.
Old Feb 27, 2021 | 12:18 AM
I have a mustang 69 And I have the same eccentric Did you not put the pin?
I have a mustang 69 And I have the same eccentric Did you not put the pin? Is it supposed to be without the pin?
Old Feb 27, 2021 | 09:04 AM
5851a's Avatar
5851a
The camshaft dowel pin is shorter on the 2 piece eccentric engines. to allow the little tab on the center eccentric to set in the holes. Older single piece ones need the long dowel pin to protrude out past timing gear to locate eccentric.
Old Feb 27, 2021 | 09:49 AM
440 sixpack's Avatar
440 sixpack
Correct. the washer on the cam bolt partially covers the pin to make sure it stays in place.
Old Feb 27, 2021 | 01:18 PM
Pin size and width
do you know how long is the pin? And what is the width? Or where I can buy it from?
