hey guys its been a while since ive been on here...but i had a screetching sound coming from my clutch... with the pedal in and out...dropped the trans and found my throw out bearing failed... now i have somewhat of a groove ground in the "fingers" of the pressure plate... im ordering a new throw out, pilot and clutch fork from parts guy ed...just wondering if its ok...
well i guess when the release bearing went, it took out my fork. (theres a real nice homemade notch ground into it) and simultaneously rubbing the pressure plate... im not sure if i should file them down or is it shot?
I dont know either. Maybe someoen else will pop in here and give up a little advice.
Is there a new improved throwout for this model? Maybe I am thinking of a new model. I remember some sort of improvement but maybe its a 99 or later. not sure.
Ive seen the fingers look worse I have not reall seen them wear in one spot more that the other as your looks to have been doing. Maybe the fork helped it to look that way
The problem I see is that the fingers will be ridding on each out side edge of the bearing.
If you put a straight edge on one of the fingers how much of a gap do you have?
If I were you, I would just order a new clutch kit from Valair, have the flywheel resurfaced, and get a new clutch fork. You already dropped the transmission, you might as well get new parts in there so that you know everything's good.
Mike I don't have a measurement for you...deep enough to worry
Joseph, normally I would err on the side of caution and put a new one in but... and I say BUT- this clutch only has 45000 miles on it
