horn works only when engine off!
Old Dec 19, 2011 | 03:17 PM
barryf's Avatar
barryf
87 F250: getting ready for inspection, thought i had horn fixed by knocking some corrosion off the fuse (truck has been sitting about a year). final check before taking to inspection; found that the horn only works when engine ignition is in the "off" position, not when running or in the "on" position!
any ideas about this? btw i have a replacement column and ignition switch, still using the original wheel that had cruise control. but replacement column didn't have that. but i dont get why turning the key to on seems to de-activate the horn.
barry f
Old Dec 19, 2011 | 03:26 PM
White 97 xlt's Avatar
White 97 xlt
I don't know where to tell you to look, but it sounds like a ground problem at the column...
Old Dec 19, 2011 | 06:25 PM
F150xlt's Avatar
F150xlt
Here's the schematic for a 88. The 87 should be the same but the color
of the wires could be different.
When you don't have cruise control and the horn switch is depressed
12 volts from Fuse #16 which is hot at all times is supplied to the horns.
If you have cruise control, there is a Horn Relay. When
you pressed on the horn switch it applied ground to the coil
of the Horn Relay which closed the relay contacts. 12 volts from
Fuse #16 which is hot at all times then supplies 12 volts to the horns.
Old Dec 24, 2011 | 03:14 PM
barryf's Avatar
barryf
thanks all.
i decided i needed to take the easy way out, since i wanted to get truck inspected before snowfall. for about $20 for button, relay circuit, wiring, i just installed a horn button on the dash.
barry
Milwaukee,WI
Jan 26, 2022 12:19 AM
daragsdale
Electrical Systems/Wiring
Dec 7, 2005 12:20 AM
83250XL
Nov 27, 2005 11:40 PM
63Fairlane500
Oct 11, 2003 11:53 PM
rjjr38
Jan 27, 2003 11:29 AM
