4" Exhaust
Old Dec 29, 2011 | 05:35 PM
locknload223's Avatar
locknload223
Originally Posted by Joe28443
I liked my quiet exhaust too. I did however notice a slight vibration after the install when I am cruising at low throttle. Don't know what that is.
It's the Chevys and Dodges trembling next to you.
Old Dec 29, 2011 | 05:53 PM
jd58980's Avatar
jd58980
4" MBRP exhaust showed up today...but cant install until next weekend.
Thanks Clay....
Old Dec 29, 2011 | 06:36 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Thanks Clay....
Good to hear. Sorry you have to look at it until then
Old Dec 29, 2011 | 07:23 PM
gmcbride's Avatar
gmcbride
I am wondering if you can clean out the stuff inside the CAT, leave it in-line for emissions and be good to go?
Old Dec 29, 2011 | 07:34 PM
Riffraff Diesel
PREMIUM SPONSOR
Yes, it will still function fine and you should see some mpg improvement.
Old Dec 30, 2011 | 08:35 AM
jd58980's Avatar
jd58980
I may be able to install it on Monday...Hope to get it installed. Will let you know how it goes and will try to take pictures.
Old Dec 30, 2011 | 08:40 AM
archtaan's Avatar
archtaan
Here is a short cell phone vid of my mbrp 4" on the excursion. It really sounds good under load at speed. I think you will be very happy!
2011-12-25_12-52-50_781 video by archtaan - Photobucket
Old Dec 30, 2011 | 09:22 AM
FallstonYJ's Avatar
FallstonYJ
Mine is straight piped; (we don't have inspections in MD on diesels........yet!), and I don't really notice that much noise in the truck unless I am really pushing it mostly pulling my 20' enclosed trailer or pulling my Jeep.
Guess maybe I'm just used to it now?
Old Dec 30, 2011 | 03:15 PM
Screamin6's Avatar
Screamin6
I just got done installing an MBRP 4" on my Ex. What a PITA!
Worst part is the pipes are heavy, and lining up everything (don't even try to install the down pipe without help). Getting the down pipe in was a puzzle in itself, trying not to tweak the flange.
I used band clamps from NAPA so as not to crimp the pipes. Removing the passenger rear shock was also a big help.
The truck now is quiet inside compared to the stock system. I would have thought otherwise.
Oh well, time to cleanup and tend to my wounds after this 2 day battle.
Old Dec 30, 2011 | 03:31 PM
locknload223
Wow, mine wasn't bad at all. I loosened the down pipe clamp at the turbo, cut the stock DP before the crossmember then wiggled the bottom of the DP and it popped right off the system. Wife helped hold the bottom of the DP as I aligned the clamp then she went inside and I lined everything else up. My dad had to remove the rear shock on his install too. I didn't have to. I thought it would be harder with airbags but it wasn't. It's weird how different similar installs can be.
Anyway, good job. Put your feet up tonight and enjoy your new exhaust.
Old Dec 30, 2011 | 03:49 PM
Screamin6's Avatar
Screamin6
Originally Posted by locknload223
Wife helped
My wife did not help, key difference.
I struggled for at least an hour trying to figure out how to get the down pipe into position, and another 1.5 hrs trying to get it to line up with the turbo. I packed it in at midnight. This morning my wifes foster daughter helped hold up the DP and it was lined up in less than a minute. Yay! (I hope the V-Band clamp is on correctly).
I was trying to make sure that no parts were hitting the body, also. So I took my time aligning the system which took a while. Looks like I had about 1/4" - 1/16" clearance on the DP to this plastic heat shield near the trans pan. At least if the DP hits anything there isn't a knock sensor to go off! (Been there, done that).
I'll give it a few more heat cycles before checking and re-tightening bolts again.
Old Dec 30, 2011 | 04:19 PM
njneer1's Avatar
njneer1
Good read......I haven't done exhaust because I am afraid of the dreaded "drone" at a highway speed......I guess " not too bad" is relative to the owner.....anyone do a Magnaflow ? .....claims are that they are quieter.
Old Dec 30, 2011 | 04:24 PM
  #28
TXtinct's Avatar
TXtinct
You'll shoot your eye out
Since we're posting some vids anybody want to guess which system I used. Some of you already know so shhhh... It's a quick phone vid so it's just sitting on the ground...
Old Dec 30, 2011 | 04:56 PM
  #29
hasteranger's Avatar
hasteranger
I am happy with my stock exhaust but it is getting some pretty serious surface rust... I will probably change it out to whatever the quietiest stainless aftermarket system is. Kinda disappointed that the stock one is rusting so bad. Nothing else under my truck has a spot of rust on it.
Old Dec 30, 2011 | 05:10 PM
  #30
locknload223
Not even the driveshaft? I figured Ford sprayed those with sea water at the factory.
