7.3 coolant loss
Old Dec 18, 2011 | 04:00 PM
COE Guy's Avatar
COE Guy
7.3 coolant loss
Hi, I'm new to the diesel world and have chance to buy a 2001 7.3 with 160k on it but the motor has a blown head gasket (This is what the seller says). I am going to look at it myself this week and from what I've read here the 7.3 are not gasket blowers. I'm leaning towards cavitation of the block. Is there any way to tell by the coolant or oil? Check strips etc? Compression test? Any ideas that you can do while looking at it where it sits would be great. Thanks Ray
Old Dec 18, 2011 | 04:25 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Why does the seller think it's blown? What are the symptoms?
Old Dec 18, 2011 | 05:48 PM
COE Guy's Avatar
COE Guy
Just talked to him once and didn't go that far. I'll be calling him again for more details.
Old Dec 18, 2011 | 06:07 PM
clux's Avatar
clux
Most shops should be able to test the coolant for hydrocarbon contamination to detect head gasket problems.
You are correct, I've hardly ever heard of a blown headgasket
Old Dec 18, 2011 | 09:39 PM
COE Guy's Avatar
COE Guy
Thanks for the replies. Anyone else?
Old Dec 18, 2011 | 09:48 PM
White 99's Avatar
White 99
If the owner decided it has a blown head gasket just because it has water in the oil or oil in the water there are other more likely causes than a blown head gasket. Might be a real good deal.
You might ask what kind of anti freeze he has been using. I have not read of many of the later ones have a cavitation problems either. I think the cause of cavitation pin holes is old or wrong anti freeze; though I suppose there are other causes.
Last edited by White 99; Dec 18, 2011 at 09:55 PM. Reason: thought of something else
Old Dec 18, 2011 | 10:59 PM
big poppa's Avatar
big poppa
Ask more questions, if he's willing to sell he's got to expect questions on your behalf, especially when things arn't right. Get back to us. Could be something like bad injector o-rings or cups if there's oil or fuel in the coolant.
Old Dec 19, 2011 | 12:01 AM
blakeusa's Avatar
blakeusa
I believe Blackstone labs will check/ test motor oil and coolant levels in the oil.
check out site their web or give them a call
Old Dec 19, 2011 | 05:07 AM
COE Guy's Avatar
COE Guy
Yes I'll be asking more questions. Seems like he just wants to get rid of it and update to something newer. The more I read on the cavitation the more I'm thinking it might be something else. Thanks for all the replies everybody, any more ideas on what it could be or things to look for? I'll post when I get more info on it. Thanks Ray
Old Dec 19, 2011 | 08:05 AM
clux's Avatar
clux
Yeah the cavitation issue was more of a problem with the IDI 7.3 that was a different block. A far more common problem with our engine is erosion at the water pump from SCA flakes in the coolant.
But if there's enough coolant in the oil, it still may have wiped the bearings and need a full rebuild regardless of the source of the coolant.
Old Dec 19, 2011 | 09:42 PM
COE Guy's Avatar
COE Guy
Okay talked to the seller and he said that it would pressurize the radi and overflow tank. I asked if there was coolant in the oil and he said that he didn't look to see. I'm going to look at it later in the week if he still has it. I'm thinking cracked head maybe or injector cups. Any more ideas? Thanks for all the help so far. Ray
Old Dec 21, 2011 | 04:57 AM
COE Guy's Avatar
COE Guy
Bumpity...Bump.....Bump... any thoughts? Also Merry Christmas everyone
BIGG HUBB
Dec 17, 2015 06:58 AM
mclaughlin16846
Feb 27, 2014 07:32 AM
lemonshindig
31
Sep 30, 2010 01:01 PM
bowhunt24
2004 - 2008 F150
Sep 25, 2008 07:26 PM
tunruh
Nov 26, 2003 11:02 PM
