2nd blown 7.3 question
Old Nov 24, 2003 | 09:34 PM
tunruh's Avatar
tunruh
Just got a call from a friend who has located a 7.3 with 80,000. Says it has a blown head gasket and posible burned ehhaust valve. Not aware that head gaskets were a problem with 7.3's. Are the valve seats replaceable? If I decide to use this as a replacement for my E350 (see prior post) it will make for the easiest job, but before I do, what other things should I check ?
Old Nov 25, 2003 | 05:08 PM
fordiesel69's Avatar
fordiesel69
Not always, but generally if a 7.3 cavitates, it takes the head gasket with it. A USED engine 9 of 10 times generally has falsified mileage. BE CAREFULL.
With only 80k I find it hard to beleive that it has those problems.
Old Nov 25, 2003 | 06:43 PM
tunruh's Avatar
tunruh
my understanding of 'cavitate' is the injector pump is sucking/pumping air instead of fuel. ??
Obviously I have to rebuild, so now;
what other things should I look for during the rebuild?
who's got the best rebuild manual?
where's a good place for parts?
Old Nov 25, 2003 | 09:48 PM
fordiesel69
Cavitation is when the cylinders get "pinholes" in them allowing coolant to fill the cylinder resulting in nowhere for the coolant to go except to the weakest part; the head gasket or the connecting rod.
This is a result of not using any supplimental coolant additives. I do suggest you read up on this as you will find it very interesting.
Old Nov 26, 2003 | 11:02 PM
Spectramac's Avatar
Spectramac
80K is a prime mileage for a pinholed block. That's how many were on the first one we discovered back in the 90s. I've never had to put headgaskets on a 7.3. Not without doing a total rebuild anyhow.
