Broke down
Old Dec 18, 2011 | 12:56 PM
Vinford's Avatar
Vinford
Broke down
02 7.3
Broke down mile 54 Alaska highway
It's Sunday so no shops and im 800 Kim's from home
Changed the cps and it seemed ok for about 20 miles the the CEL came on again. I moved wires around on valve cover on drivers side and that seemed to make it start? Any ideas
It starts acting up going up hill
? I'm sitting in it now and it idles fine
Old Dec 18, 2011 | 01:09 PM
puller45's Avatar
puller45
Fuel filter ?
Old Dec 18, 2011 | 01:24 PM
tdpower's Avatar
tdpower
The wires can rub on the drivers side valve cover. Something easy to check.
Old Dec 18, 2011 | 01:52 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
In tank screens. Sounds like a fuel issue.
Old Dec 18, 2011 | 08:50 PM
Vinford's Avatar
Vinford
Well I borrowed a truck and left mine behind
Old Dec 18, 2011 | 08:58 PM
snakedoc's Avatar
snakedoc
sounds like fuel PSI is low, cant keep up with the truck when pulling. it should be ~65psi.
Old Dec 19, 2011 | 01:40 AM
Vinford's Avatar
Vinford
I left it behind and came home in a borrowed truck .
When I turn the key on the "wait to start" light doesnt go out every time and when it doesnt go out the truck wont start. (That mean anything?)
A couple of times I unplugged the plug going to the valve covers then plugged it back in and it started.
It seemed ok after I changed the CPS but at the first big hill climbing out of the Peace River the light came on and it tryed to quit.
I drove back to Fort St John and drove around town for 1/2 hour and it seemed OK.
I have a Edge Evalution chip in it, thats been in for a couple of years with no problems.
I tryed to unistall it and when I plug it into the computer port under the dash nothing happens?
Its like theres no juice to the port?
Old Dec 19, 2011 | 07:43 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
I forget what fuse it is, but the fuse controls the cigarette lighter and the OBD II port.
Old Dec 19, 2011 | 09:21 AM
BillyBob69's Avatar
BillyBob69
If you unplug the harness then plug it back in and it sometimes start....could be you are moving it enough that the connection under the valve cover is making/losing contact. May have to pull the valve covers and check the inside connection. Although that would only get it to run like crap. Shouldn't kill it all together.
Also check the ICP sensor. It sits on top of the drivers side head towards the front. If that has gone bad, oil has seeped into the electrical side and is causing bad readings to get to the PCM. This will shutdown the truck. Just replaced one for a friend who was having the same issue.
Old Dec 19, 2011 | 10:21 PM
Vinford's Avatar
Vinford
Yup thats what Edge told me when I emailed them , it might be a fuse.
That might solve that problem but i still have the other one.
I dont think its fuel related.
Would the UCV (Valve cover gaskets) make it die out?
Old Dec 19, 2011 | 10:26 PM
Rose Clifford's Avatar
Rose Clifford
my fuse 13 went which was OBD and cig lighter and it didn't affect performance at all
Old Dec 19, 2011 | 11:04 PM
Vinford's Avatar
Vinford
ya im just trying to uninstall my chip and i couldnt , that was just part of my problems.
Thanks ill check it out.
Old Dec 20, 2011 | 07:17 PM
Vinford's Avatar
Vinford
Can anyone tell me the symptons when the valve cover gaskets are screwy?
Im trying to gather up everything i need to go back and get my truck.
Old Dec 20, 2011 | 07:28 PM
tennesseecoalroller0's Avatar
i would say just like everyone else is saying check your uvch if there good pull the harness off the top of the icp and see if it will run if none of the above helps look in the valley down near the back of the hpop and see if the tin nut has came loose from the ipr valve if so that could be your problem as well.. just my 2 cents hope u get it back on the road
Old Dec 20, 2011 | 07:34 PM
diesel-fitter-bum01
Uvch symptoms are loss of power,rough idle,smoke,and hard start.
