Help!!! 390 won't start after header install
Old Dec 18, 2011 | 10:48 AM
70SportCustom's Avatar
70SportCustom
Hello. New to the forum. Installed headers the other day. Had to jack up the motor to get them in. Truck started, but my tach was bouncing around, and the motor was popping out the exhaust. Now it won't start. Has new HEI dist, wires, plugs. Ran great before the header install / jacking up the motor. Feel pretty dumb at this point. Am thinking that the motor is not grounded, and is affecting the dizzy. Please help, this is my daily driver, and it is snowing. Can't get to work without help.
Old Dec 18, 2011 | 12:06 PM
CougarJohn's Avatar
CougarJohn
Welcome in, Buddy.
This is a headscratcher since obviously there is no connection between exhaust manifolds and ignition. You have disturbed something.
The tach counts pulses in the primary and the fact that it is bouncing up and down suggests some primary misfire. I would start by double checking the 12v. connections to coil, distributor, switch to see if you have jerked anything loose in moving that engine around. Check and tighten the ground strap from engine to firewall. Let us know what you find.
Old Dec 18, 2011 | 01:54 PM
70SportCustom
Thanks for the welcome. Nice to have a reply. Getting 12v to the distributor. Checked engine grounds with a volt meter and they are fine. Getting spark to the plugs. Getting fuel to the carb. Motor has been gone through and has always started. Spark, good compression, fuel, should make some kind of noise. Don't understand how the timing could be off, but it is the next thing that i'll check. Pulling hair out.
Old Dec 18, 2011 | 02:00 PM
MIKES 68 F100's Avatar
MIKES 68 F100
did you remove plug wires when installing headers ? if so check for not seated plug wires or wrong wires to plugs (firing order)
Old Dec 18, 2011 | 06:09 PM
CougarJohn's Avatar
CougarJohn
You have a tach. When you are cranking does it move up to 200 rpm or so? Indicates the primary is functioning. Have you looked at all slide connections that might have been disrupted when you jacked the motor? Distributor connector? Could you have knocked the distributor loose? Timing?
Calm down. You have fuel and spark. Flooded?
Charge the battery up full, open the throttle full, crank it for ten seconds to clear its throat. Wait ten minutes, give it choke and it will fire.
Old Dec 18, 2011 | 06:21 PM
CougarJohn's Avatar
CougarJohn
Added thought:
You may be flooded and may have wet the plugs. Do what I said above and if it doesn't work pull the plugs and dry them off with a bernzo torch. You obviously know what you are doing.
This is one of the situations where the old guys wish that we were hunching over the fenders to get you started.
Semper Fi
Old Dec 20, 2011 | 09:04 AM
70SportCustom
Thanks for the advice. I got it started. Ran it down the road. Was smiling ear to ear, got it home, turned it off, and it wouldn't start. The only thing i did was move the dizzy a bit, checked the number 1 plug wire to make sure it was seated, took off the distributor cap for the millionth time, put it back on, got in the truck and it fired right up and ran strong. Drove it for a while, ran fine. Shut it off, and now it won't start again. Plugs were always dry, so i know it was never flooded. It should run, i just don't get it. Not much hair left. Thanks for the help.
Old Dec 20, 2011 | 09:16 AM
rustywheel68's Avatar
rustywheel68
when you say that it won't start- what are the symptoms?
slow cranking, no cranking, good crank but no fire, etc.
MIKES 68 F100
check your wires to dizzy , sometimes they are old and cracked , 12v could be jumping out of crack before it gets to dizzy , or you just have corroded connections , if in doubt just hack it off and run a new wire . at this point it's worth a try.
Old Dec 20, 2011 | 09:25 AM
MIKES 68 F100
just a thought , how old is coil ? my 68 when i first got it would run then just stop , turned out the coil would fail when the engine got up to temperature .
Old Dec 20, 2011 | 11:09 AM
70SportCustom
Appreciate the help guys. To answer rusty68- the motor turn over fine. It gets spark to the plugs. The timing hasn't been changed. Ran great, came home, shut off, now won't light off. The dizzy is a new pro comp HEI unit. I am starting to think that it might somehow be my ignition switch? I am getting 12v to the dizzy, but maybe i am not while i am turning the motor over due to an old switch? Sooo frusterating. The truck runs great, it just won't start anymore. I have spark, fuel, compression. What the heck?
Old Dec 20, 2011 | 01:06 PM
MIKES 68 F100
run a jumper from battery to dizzy , basically hot wiring it . should tell you if old wires /switch is problem .
be prepared to pull wire , only way to shut engine off .
Old Dec 20, 2011 | 04:08 PM
70SportCustom
Problem Solved
I finally got it. It was the ground strap under the coil on the HEI. The coil wasn't grounding thru the strap becaseu of a screw that came loose. What a PITA. Seems stupid now, but it had me on the ropes. Thanks to all that tried to help. I will try to return the favor if i can. Take care. 70sportcustom.
Purplepills
33
Aug 31, 2015 09:51 AM
Biggi
17
Aug 15, 2011 07:14 PM
Nathane
General Automotive Discussion
Oct 22, 2007 11:21 AM
SoonerFord
Sep 28, 2004 01:28 PM
john1972f25
Dec 28, 2002 09:07 PM
