Rough Ride Revisited
Old Dec 18, 2011 | 09:54 AM
fasthauler's Avatar
fasthauler
I already posted this in the driveline forum, but thougth I would post it here as well in hope of getting more input.
I have posted before about my trucks stiff ride and received several suggestions. I need to revisit this issue. I have confirmed that a lot of the stiffness comes from the shocks. I put new set of sens-a-trac shocks on a year ago. I was at the local hardware supply store yesterday and was talking to another gearhead and he stated that I could put air shocks on and the stiffness can be adjusted with the air pressure. He claims the shocks become softer as the air pressure is reduced. Does anybody have any experience using air shocks. I am not interested in load handling I am interested in making the truck ride more like a car. If not, I am going to have to give up on the truck due to my wife’s bad back. The truck rides smooth with the fifth wheel in tow. The problem is when driving solo.
Old Dec 18, 2011 | 11:39 AM
raytasch's Avatar
raytasch
Believe Nothing
Since you don't give specifics on the truck, size, GVWR, etc I'll just go with generalities.
Stiff ride is the result of spring rate vs weight of the truck, weight it is designed to haul. Doubt if you find the shocks contribute much to the stiff ride. Air shocks will not do much make it ride easier unless you reduce the spring rate/capacity of the existing springs and then inflate the air shocks to support the truck. Air bags would work better than shocks if you go this route. Tire stiffness is a factor in ride, a lower pressure may help. Respectfully, if you want it to ride like a car, buy a car or ride around with 1000 lbs of load in the truck.
Old Dec 18, 2011 | 02:11 PM
fasthauler's Avatar
fasthauler
It’s a 77 Ford F250 with a 10.25 Sterling in the rear. I took the overloads off and put air bags on. I took a leaf out of the rear springs. I have had the truck for 30 years and don’t want to give up on it, but the problem is unloaded. If I hit a rut with the thing unloaded I have to take my wife straight to the doctor and I would like to figure a way to avoid this. Young people don’t realize that when you get older the body won’t take the pounding it once did. I temporally took the shocks off and wrapped a chain around the axle and frame to keep it from bouncing out of control and drove it across some ruts and it rode just like it does loaded. It would be good if I could eliminate the shocks, but it is obviously dangerous to try to drive without shocks. That is why I was asking for help from anybody that has experience with air shocks to tell me if the kid in the hardware store knows what he is talking about. If so, I will get a pair of air shocks and put them on. Otherwise, why waste the money.
Old Dec 18, 2011 | 05:27 PM
"Top Fuel" Bender's Avatar
"Top Fuel" Bender
shocks help dampen and control spring movement/ oscillation
yes, a blown shock, or heavy duty gas filled unit will effect ride
but it's your springs not the shocks giving you your ride quality
If you do a search on here there's some info on swapping out the rear springs to 54" chebbie springs and re-setting the rear shackle angle
jc302x
Feb 16, 2019 04:29 PM
fergusonicford
May 11, 2009 05:40 PM
davidbickle
1978 - 1996 Big Bronco
Dec 19, 2004 07:09 AM
ztruck
Jul 21, 2004 06:06 AM
