so i had some problems with my truck about a month ago and just now got the time to start to work on it im going to replace the egr cooler and oil cooler but i need to clean the intake with oil and carbon in it anyone know of a good way to clean it or someplace to get it cleaned in the Seattle/Tacoma WA area
The purple power works the best when i used carb cleaner it just laughed at it.
What He said
That purple power is good stuff
I would tip it up and soak 1/2 of the intake at time in a container
You could hot tank it but if yor putting the egr back on it its just going to fill backup with junk again
EGR Deleate is the way to go to keep things clean
ok so iv read that the motorcraft gold is what i should use in my truck but the coolant in the truck is green so acording to the ford parts web page i shouldnt put the gold in what do yall think flush the system and go with gold or what
or am i just going crazy and have no idea what im talking about
Soak with purple power and take it to the car wash and blast it out. Worked good for me. Do the ccv bipass and that will help as well. You could also use Zerex G05.
