Oven cleaner?
Old Dec 5, 2017 | 09:01 PM
xaviar's Avatar
xaviar
Oven cleaner?
Now that I have your attention.
Came across this video on cleaning your intake with oven cleaner.
Anyone heard of this method. Looks quite thorough.
I'll be giving this a try this weekend. My new EGR cooler should be here Thursday. So, I'll have it apart and clean the intake while I'm at it.
Tell me whatcha think?
Old Dec 5, 2017 | 10:00 PM
TooManyToys.'s Avatar
TooManyToys.
You have to be real careful about using caustic lye on aluminum. It gets funky real fast.
Old Dec 6, 2017 | 03:08 AM
Yahiko's Avatar
Yahiko
Just go get some Extreme Simple Green® Aircraft & Precision Cleaner.
Industrial | Extreme Aircraft Precision Cleaner
You can find it at pilot Supply shops. Grainger supply and Amazon.
Runs about $29 a gallon and is aluminum friendly. That is what I used on my
intake and it really cleaned it up.
Old Dec 6, 2017 | 06:03 AM
TooManyToys.
It what I used Sean, after reading one of your earlier posts. Pressure washer, too.
Old Dec 6, 2017 | 12:14 PM
Yahiko's Avatar
Yahiko
I started using it fo a lot of my hard to clean stuff after the one time I was cleaning
a small jet with a very dilute spray and a hot water pressure washer. I was shocked
how little work it took. I think I only had to brush around a few spots the stuff works
very well. I also found that on the plastic hood liners that Ford puts in the Rangers
clean up very well by spraying it onto the liner and letting it sit for 5 minutes and then
just hosing it off. The liner looked like new after that. All the sues and stuff that had sprayed
the liner over the years was gone. When I had the intake off the truck a few years back
I sprayed the inside with undiluted and then let it sit for a while before sticking in a
large aluminum tub I have with it full of water and cleaner. I let it sit and soak for a few
hours and I think it would of worked faster had I dropped a pump in to move the water
around, I used the pressure washer and to keep from getting any splash back I wiw it all
under water. By the time I was done the intake was nearly spotless.
Old Dec 6, 2017 | 01:30 PM
xaviar's Avatar
xaviar
Gotcha.
I'll revert back to old reliable simple green.
Old Dec 6, 2017 | 01:51 PM
Yahiko's Avatar
Yahiko
The green stuff is NOT aluminum safe.
Old Dec 6, 2017 | 03:40 PM
diesel_dan's Avatar
diesel_dan
Yeah, I too was a long time user of the old green stuff for under hood, dirtbikes, etc., until Sean pointed out how it oxidized, or attacked, the aluminum. Making new stuff look old pretty quick.
I bought some of what he recommends at Amazon....
Old Dec 6, 2017 | 05:21 PM
WatsonR's Avatar
WatsonR
How about Purple Power... works well on Magnesium chainsaw cases and is plastic and sticker friendly? No scrubbing, spray, wait a few minutes, hose it off.
Old Dec 6, 2017 | 08:59 PM
Yahiko's Avatar
Yahiko
Extreme Simple Green® Aircraft & Precision Cleaner. Safe on plastics.
The stuff is a Boeing approved cleaner.
I had the resent chance to try out Purple Power. I'll just say I was not impresses.
Old Dec 7, 2017 | 04:40 PM
87crewdually's Avatar
87crewdually
That's all I use. We are talking about a thick piece of cast aluminium intake manifold here. Not bare aluminium panel of an airplane.
Old Dec 7, 2017 | 05:15 PM
WatsonR's Avatar
WatsonR
and it's not expensive, $5 or so a gallon. Used straight, never hurt a sticker or plastic. Don't like Simple Green, makes my nose hurt from the smell.
Old Dec 7, 2017 | 05:22 PM
87crewdually
I get it in the 2.5 gallon container. When it's empty, it makes the perfect container for capturing the coolant from the radiator for service.
Old Dec 7, 2017 | 05:50 PM
Yahiko's Avatar
Yahiko
It does not smell the same as the green stuff.
Extreme Simple Green® Aircraft & Precision Cleaner is clear and the sent
is no where near the same.
Old Dec 7, 2017 | 08:35 PM
xaviar's Avatar
xaviar
Picked up my Simple Green Extreme today. When I got home. My EGR cooler was waiting on me.
Also going to purchase the Uview 550500 ll coolant fill kit. It's suppose to eliminate air gaps while filling the cooling system.
I'll post pics as I go along in the other tread I have running
Eddy
