Bizarre problems
Old Dec 24, 2011 | 04:42 PM
steventothemax's Avatar
steventothemax
FYI fuel disconnect line is 1/2 inch. Posted as 3/8 or 5/16 multiple places. Still waiting for UPS man to deliver pump so we can get to grandma's for christmas.
Old Dec 24, 2011 | 07:07 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Sure hope this will be a MERRY Christmas for you!!! Good Luck. I'd ask Santa for a Scan Gauge II for Christmas tho.....
Old Dec 24, 2011 | 09:57 PM
steventothemax
Thanks. Sadly the fuel pump didn't come in time ( even paid extra for shipping) so we won't get to spend Christmas with grandma.
I do have a $30 bluetooth OBD and a $6 app for the android which seems to do everything that the scangauge will do. Pretty cool device.
Old Dec 24, 2011 | 10:01 PM
dukie1877's Avatar
dukie1877
Sorry about that what a bummer. Maybe you were not supposed to be on the road you never know.
Old Dec 24, 2011 | 11:35 PM
steventothemax
Thanks and I agree.
Old Dec 25, 2011 | 06:27 AM
DevilDocTater's Avatar
DevilDocTater
Master of Disaster
You dont have to pop any line to actually replace the fuel pump itself. No need to replace the entire HFCM.
Old Dec 25, 2011 | 09:42 AM
steventothemax
Doc could you clarify. I thought it was necessary to pull the HFCM take it apart and put new pump into it?
Old Dec 26, 2011 | 06:46 AM
DevilDocTater
Master of Disaster
Steve look on the forward end of your HFCM (opposite of the fuel filter cap) and there is a set of wires connected to a round head (thats actually the fuel pump) with i think 3 screws in it. The HFCM is just a housing really, you can replace the actual pump without buying a whole new HFCM. Search for a 6.0 fuel pump on ebay and you will see what it looks like. Its a black tube about 1 1/2 inch in dia with a flat dome head on it.
Old Dec 26, 2011 | 08:26 AM
Jimbob8's Avatar
Jimbob8
Originally Posted by steventothemax
gauge installed. 40 psi sitting in driveway (already have blue spring) time to install new fuel pump.
Was this pressure KOER or KOEO, I would start with filters, 1 bad tank of fuel can plug a filter. If KOEO pressure comes to 55+ & KOER is 40 then it could be filters or HFCM inlet restriction (tank pickup plugged) Hate to see ya change pump & still have same problem.
Jim
Old Dec 26, 2011 | 08:44 AM
steventothemax
Doc, I have the pump by itself already coming. Just wondered if there was an easier way to put it in. Actually seems pretty easy to yank the whole hfcm.
[quote=Jimbob8;11198350]Was this pressure KOER or KOEO, /quote]
I really don't know the difference. Pressure was taken at fuel test port. Surprisingly the fuel pump is about the same cost as a premium set of fuel filters.
Old Dec 26, 2011 | 08:59 AM
steventothemax
Gotta love google. Pressure is the same with engine off or on.
Old Dec 26, 2011 | 09:10 AM
Jimbob8's Avatar
Jimbob8
Fuel pump most likely, I would pull unit & do on bench, you can clean everything & no crap dripping in your face. Also cycle pump a few times before starting to clear air. Good luck
Jim
Old Dec 26, 2011 | 09:25 AM
  #28
bismic's Avatar
bismic
Here are links to the individual pump and to a diagram on the fuel pump and where it resides in the HFCM (this was in your other thread on the subject):
HFP964 Feed Pump For 2003-2006 Ford 6.0L=
From Dchamberlain
https://www.ford-trucks.com/forums/a...6&d=1324481833
https://www.ford-trucks.com/forums/a...7&d=1324481833
Thought I would add these to this thread since people may find it w/ the search feature.
Where did you get your fuel pump from? Did you pay less that $199? Any Ford part numbers (ie other than HFP964)?
Old Dec 26, 2011 | 11:07 AM
  #29
steventothemax
Thanks Jim.
Got the pump from Walbro 255 Fuel Pump : Walbro 255LPH : Performance Fuel Pumps : Cheap Fuel Pump : Discount Fuel Pump : Ford : Chevy : Chevrolet : Range Rover : Dodge Ram Awesome prices on pumps. $80 for one that would handle up to 450hp.
Thanks for the documents bismic.
Old Dec 26, 2011 | 11:14 AM
  #30
bismic's Avatar
bismic
Their drop down menu did not show a pump for a 6.0L diesel. Did you call them to get the proper pump?
