Leaking seal on rear diff.
Old Dec 17, 2011 | 01:06 PM
tonefordays's Avatar
tonefordays
Soooo.....I was underneath the truck this morning checking for leaks from last weekends tranny oil change (all good), however while I was under there decided to check around a bit more. I noticed the seal on the rear differential is leaking, where it's connected to the drive shaft. There is evidence of slinging oil. How involved is the job to replace this seal? Any links on the procedure, special tools, P/N for seal, etc.
Much appreciated.
Old Dec 17, 2011 | 01:15 PM
cartmanea's Avatar
cartmanea
Before you do anything, make sure the vent is not plugged. It is the rubber hose coming off the top of the pumpkin and going to the frame. Take it down from the frame and try blowing air into it with your mouth (not a compressor) and see if it flows easily. When the vent is plugged, the differential heating up will cause it to burp fluid past the seal.
Old Dec 17, 2011 | 01:41 PM
tonefordays
I didn't see a vent hose coming off the top for the rear diff. like I see on the front diff. There is a rubber vent tube coming off the axle tube between the wheel and the diff. that leads up to the frame. I tried blowing into this tube, it built pressure, and as soon as I released, it blew back at me. Is there a one way check valve on this?
EDIT:
BTW, I forgot to mention
2006, 6.0, CC, SRW, 4x4
Old Dec 17, 2011 | 02:31 PM
tonefordays
I removed the vent tube and fitting to check for obstruction, both were clean. Could there be an obstruction inside the axle tube somehow, keeping it from venting properly?
Old Dec 17, 2011 | 09:35 PM
cartmanea's Avatar
cartmanea
It sounds like it is venting if you built up pressure in the pumkin and it blew back at you.
SHOpar
Aug 12, 2015 05:35 AM
acm05fsu
1997 - 2003 F150
May 16, 2010 08:22 PM
gingerbreadmaniac
17
Apr 1, 2007 03:41 AM
vze2sgxa
Feb 3, 2006 06:17 PM
slowsix
Apr 2, 2002 12:44 PM
