TPS voltages
Old Dec 17, 2011 | 11:31 AM
Forddiesel17's Avatar
Forddiesel17
TPS voltages
My dad has a 1994 F 350 with factory turbo and the E4OD. Took it to a transmission shop because it was shifting weird. pulled codes said it was the VSS. replaced that all seemed good till now. Checked the voltages on the TPS. they seem fine but here they are. Center wire at idle 1.15 WOT 4.12 approx. bottom wire was 4.97 volts. The truck drove fine until last week then parked it until i had time to check it. Dad said that all of a sudden he couldn't go over 50 so he backed off then tried it again shifted extremely hard. Stopped at a business shut it off. Then got back in shifted fine for a while. He told me the o/d light only flashed a couple of times then stopped. What is going on here?!
Old Dec 17, 2011 | 11:40 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
He'll need to pull the codes as it could be a number of things.
TPS voltages are a bit on the low side.
https://www.ford-trucks.com/forums/1...ions-only.html
but i doubt it's related to his issue.
newstylecustoms
Feb 18, 2013 07:37 AM
diverstroker
18
Oct 4, 2011 04:10 PM
fjazzbass
Mar 22, 2008 07:51 PM
Hillbily72
Aug 4, 2005 09:24 AM
Dudels
Mar 21, 2004 10:35 PM
