New Pics. New Problems
Old Dec 16, 2011 | 06:26 PM
JwEaVeR96's Avatar
JwEaVeR96
Ok, so I'm at my dads until Dec. 25 so im going to try to asses the problems on the truck, then start it this spring. I hope the pics are bigger and higher quality because i used a camera this time!
Flickr: jweaver96's Photostream
Old Dec 16, 2011 | 08:32 PM
HIO Silver's Avatar
HIO Silver
Yer gettin' better JWeaver!
The air cleaner doesn't appear to be stock to your truck. It probably had a fabric or hard plastic inlet duct to get cooler and denser air which helps combustion. Same pic, I believe the big holes on the firewall are supposed be for wiring harnesses
I'd take the radio and its assorted wiring out so I don't have to look at it. Before removing, disconnect the negative cable at the battery and then trace the wires from the radio and tag them with masking tape and a Sharpie marker to note where they connected. Some are already tagged on the radio's wire bundle. Avoid cutting any factory wiring. .
The big holes are for defroster ducts. The lil holes were probably for a speaker for the (likely) AM radio. Yep, back in the day ya normally only got one speaker.
Ngeesh. Alot of that wiring in front of your heater box is associated with the fancy audio deck. The use of twist-on wire nuts is a big red flag that the previous owner was a hack... besides other things. Again, I'd remove it and clean up the wiring.
So, tell us the homework you've done. I think if you order some catalogs and look at the parts you can fiigure out alot about these trucks. Not only how much parts cost but many catalogs have exploded drawings for your reference.
Old Dec 16, 2011 | 09:00 PM
JwEaVeR96's Avatar
JwEaVeR96
been tearing apart half price books stores for manuals, info books, etc. i can only find 73, 77, 79, etc. Researched the VIN and found out its a 302 and a 1970 (not a 71)... Going to see my uncle this weekend who gave me the truck so i can ask him about it
77Hulk
Sep 23, 2016 04:25 PM
burnthelight88
16
Sep 1, 2015 02:45 PM
letrain
Jun 4, 2004 10:08 PM
mcspare
Apr 26, 2004 12:00 PM
cheesedog1
Aerostar
Jun 26, 2003 12:17 PM
