Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Banks Transcommand + Punisher VB?? Lightning guys?
Old 01-28-2012, 04:14 AM
cbakker's Avatar
cbakker
cbakker is offline
I just got my punisher VB from paul, and he told me that I probably don't need both. I already had bought the transcommand and I would still like to use it.
My specific application;
'97 F250HD
460 + E4OD
Have anyone seen any antagonism or negative effects of running the two together?
I'm also looking for any info on using a 6 bolt TC with the 460+E4OD combo.
I can't find any 6 bolt flex plates for the 460 in any year.
Old 01-28-2012, 11:07 AM
Lead Head's Avatar
Lead Head
Lead Head is offline
Shifts might be a bit too hard for your liking possibly?
We did a trans-go shift-reprogramming kit on my friends truck, but we had to fine tune the shift pressures with the tuner to get it where he liked it.
Old 01-28-2012, 11:39 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
As mentioned above, you can change the TV pressure values for shift transitions, and that will help dial it in nicely.
I lowered the values under normal driving conditions, so the shift transitions or nice and easy. For heavy throttle conditions, I raised those values so it yields a nice snap for each shift.
I've been running/abusing a Circle D converter for years now and no problems to speak of. It's a multi-disk lockup that is much stronger than stock with a 3000 stall speed (you can get them with a lower stall speed too). Their website doesn't have info for E4OD applications so it'd be best to call them.
Old 02-05-2012, 12:50 AM
1925mosin's Avatar
1925mosin
1925mosin is offline
I have the Banks on my 94 lightning. It shifts hard and it takes some getting used to. but you stop noticing it after a while unless you have a lead foot :P
Old 02-05-2012, 12:40 PM
Blown349's Avatar
Blown349
Blown349 is offline
I'd try the valve body alone then add the banks if you want firmer shifts.
Old 02-07-2012, 11:49 AM
Killer Ride's Avatar
Killer Ride
Killer Ride is offline
Definitely run the valvebody first. Mechanical is always better than a computer for Tranny upgrades. Also a firmer shift is actually better for the longevity of the transmission. Smooth shifts require a longer transition= heat =Bad for tranny. Jus sayin
iverger
22
05-04-2019 09:48 AM
coreylasalle
02-05-2008 01:45 PM
BB94
09-27-2003 02:34 AM
adelyser
03-30-2002 07:28 AM
Rock_me
06-28-2001 09:31 AM
Quick Reply: Banks Transcommand + Punisher VB?? Lightning guys?
