When do you plug in?
If it gets much below -10 F, I prefer to plug in.
However, my truck will fire up on it's own well below that temp if I ask it to. It grumbles, cackles, shakes, groans, and complains for a minute or two, but it will start right up.
Brook, when it gets around 32F, I just plug in when the truck has to be outside. I have read on here from previous posts that folks do all sorts of benchmarks. Some in freezing areas never plug in, just preference I guess. I think the truck starts easier when out in the cold if it is plugged in, it doesn't hurt it. You use a little power, big deal, but 3 hours on a timer is all you need prior to starting, not all night.
I think your owners manual (Diesel Supplement) says you must plug in at -20°F and below. The general owners manual says at -10°F it is recommended, for both gas and diesel. Just for reference.
Assuming you can trust your weatherman and his predictions.
They should have provided a thermal switch, so that you can plug in, and it only turns on when the temp goes below xx°F.
I use a timer set for about 3.5 hours and plug it in any time it's below freezing. I love the truck kicking out warm air within about 3 min of start up and not having to let her idle more than anout 2 min before pulling away from the house!
I have not yet plugged my truck in. There is a plug buried somewhere in the front bumper I'm sure. Some day I'll have to locate it.
So far the old gal has started just fine in temperatures down to -15F. 5W-40 Rotella probably helps.
Lou Braun
Lou Braun
Here is a set up that might interest you folks.
Wow, the block heater really makes a difference! - Page 2 - Ford Powerstroke Diesel Forum
A timer set to not start when the temp is higher than the thermostat.
