You really should not need it, but it you want to, get a high amp timer and set it up to turn on a little while before you leave. All night will take a lot of electricity. $$$$$
You can plug her in anytime but you don't have to, these are good starting trucks and until it gets well below freezing I would not worry about it to much.
I never plug my truck in, even if there's frost on the window and it starts right up, no smoke. I guess I fail to see the point of making my electric bill go up.
PLUG IT IN FOR SURE!!! Timer is a great idea as many have one. It has been stated before but worth repeating for this conversation.... Take a quart of oil and store it at 30 degrees for 6 or 7 hours or whatever your nighttime temperatures are in your area. Once that is done open it and try to pour it out and then you will see why you plug it in and what the block heater is for.
Whatever you see come out of that quart, just remember your investment of $20,000 - $45,000 is straining to turn over 15 quarts of that stuff.
GET YOUR MACHISMO IN THE GYM.... not by bragging to your buddies that you started your truck in sub freezing temperatures without plugging it in. In reality, if they don't own a diesel they wouldn't understand what you are telling them anyhow!! {removing self from soap box} Thank you .... enjoy your winter!
I agree with both sides of this. If it is 32*F or below, I plug it in for about 30 minutes before cranking just 'cause I can and feel better. If it is in the teens, I will not crank my truck until it has been plugged in for a minimum of 1 hour.
Anything above freezing, I don't think it really matters. If I am away from home and it is supercold, I just crank it up but it sure is rough. That's why I try not to visit family in New Hampshire in the winter. You can keep that mess.
Do not forget there is a risk of fire. To say there is no risk to plugging it in would be ignoring that basic fact. These things occasionally burn trucks to the ground.
I personally never plug mine in, but I live in a warm climate. Take the advice of the guys who live in the northern plains, Canada, and Alaska. They know what works and when you need it.
Sounds like an insurance claim to me. Wonder how bad that new PSD is gonna be?
You can also get a timer and plug the extension cord into it, to have the timer come on a couple hours before you need to leave. That way the block heater isn't running all the time, reducing the electricity used as well as reducing any fire hazard.
I live in the high desert and am a voulnteer firefighter in a rural area. The reason I mention being a voulanteer is I always need to be ready to go I.E. need my truck warm. The reason I mention high desert is even in the summer our night time temps dip in to the 40's and as of last night we where down to low 20's by 10 PM. I also live in a rural area where power stroke fords outnumber compacts 3 to 1 and 99% of them are plugged in all night at least 8 months out of the year and I have never heard of, seen, smelled etc a block heater burning a truck to the ground. Not that it could not happen but if everything is as it should be and a 1 minute inspection of the block heating circut should tell you if it is you are more likely to win the lottery than have your truck burn to the ground. One step I do take when unplugging my truck in teh morning is take off my glove when I grab the plug, if it is hot I know I have cause for concern, so far it has never been hot.
When you plug in the truck, it only heats the coolant, not the oil in the pan. So the truck is still starting up on that very thick and cold oil. If you want to heat your oil you have to buy a separate pan heater for that.
Where I live (Seattle, WA.) if it drops below 20 degrees at night in the middle of winter, it's very unusual. We have a marine climate here so the temperatures are regulated by the ocean breezes that come in from the Pacific.
Lived in northern Minnesota all my 60 years .had many trucks and cars with softplug heaters in them, with temps well below zero during winter months they were pluged in many nites never had or heard of any fire problems. The tank heaters which installed in your heater hoses had problems. When you ordered a auto up here softplug heater are pretty much standard.
Here is an easy addition; Go ahead, get the appliance-grade timer, and there is an adapter you can get ANYWHERE they might sell farm supplies/stock tanks... I bet you can even get it (ahem!) ONLINE, lol... it will only activate when the temps drop below 45 degrees farenheit. This way, you can make a HABIT of plugging it in, etc, and not worry every night whether you need to or not! I use them on my own truck and the company trucks as well, they run about 15 bucks (That's DOLLARS for Tenn... don't shoot em) and they have gone three seasons so far.
