Power steering pump cap
Old Dec 15, 2011 | 05:41 AM
bigb609's Avatar
bigb609
Discovered that my power steering pump cap was loose and fluid went everywhere. The two little plastic "teeth" for lack of better word had spread out and would allow cap to kind of float loose. Auto parts guy tells me this is common thing. He also pointed out little "relief hole" (again for lack of better word). Tells me they clog causing heat to build and the plastic teeth to spread.
Questions:
1. Anyone had this issue?
2.Can anyone better explain this?
Old Dec 15, 2011 | 06:12 AM
Edgethis's Avatar
Edgethis
Get a new cap. Its like 3 bucks. It does happen. Gunk from the engine/road collect on the cap, clogging the breather hole. Then as you use the power steering, fluid heats and expands, raising the internal pressure as it can't escape out the hole.
Old Dec 16, 2011 | 03:29 PM
bigb609's Avatar
bigb609
new cap
yea i already replaced. $3.99. Just giving heads up to others who may run into same.
KRinAZ
Mar 29, 2012 01:18 PM
Tyler Burdett
May 20, 2010 09:19 PM
little_mule
Nov 16, 2009 08:59 PM
Domino'sDiesel
Feb 17, 2005 05:39 PM
