random no start .... HELP Please!!!!
Old Dec 13, 2011 | 10:28 PM
Kingjustinf-350's Avatar
Kingjustinf-350
Exclamation random no start .... HELP Please!!!!
ok so im new to deisle motors i have a 92 f-350 7.3 non turbo a few days ago i drove it and it ran amazing i parked it in the drive way over night . came out next afternoon and it would not start just cranked and cranked .. replaced batteries and had alternator checked ... so it now has new batts and altern was good every now and then it will fire run good for a second then get a high idle then rough idle and die ... also has new fuel/water sep. filter on it im getting fuel but it still wont run .... any help would be greatly appreciated ........
Old Dec 13, 2011 | 10:39 PM
Scaper's Avatar
Scaper
Are you getting smoke when your cranking it? If not you may have air in the fuel line. Im no expert though...just a thought.
Old Dec 13, 2011 | 10:43 PM
Kingjustinf-350
when cranking it smokes a little when it fires for the few seconds it smokes like a damn fog machine
Old Dec 13, 2011 | 10:49 PM
Scaper's Avatar
Scaper
Did you recently fill up with diesel? You may have water in the fuel. How long have you had the truck?
Old Dec 13, 2011 | 11:00 PM
Kingjustinf-350
i filled it upon dec. 6th before it jus wouldnt start i went a little over 50 miles then parked it came out the next day to go to work and she wouldnt start ..
Old Dec 13, 2011 | 11:01 PM
Kingjustinf-350
i got the truck in oct 2011
Old Dec 13, 2011 | 11:13 PM
Scaper's Avatar
Scaper
On the bottom of you fuel filter is a valve to drain off water that has collected from the water fuel separator. Open the valve and see if any water comes out. If you have a fair amount of water that comes out you have bad diesel which I would think would cause it to rough start with a lot of white/grey smoke. The next thing to check would be your glow plugs.
Old Dec 13, 2011 | 11:19 PM
Kingjustinf-350
ok thanks i will try that
Old Dec 14, 2011 | 01:12 AM
ADTMan's Avatar
ADTMan
Have you checked your GPs? GPs means glow plugs..lol Ok how long does the WTS light, come on? Do you hear "clicking" when you turn the key on? Don't crank more than 20 seconds. After 20 seconds, let the starter cool down for about 2 minutes before trying to crank it up again. These starters are not cheap and constantly cranking one can burn it up. Make sure you read the top stickys in this forum about GPs and GP controllers. They are AWESOME! Everything you need to know about GP systems is in those stickys. Make sure that IF you have to replace your GPs, use ONLY motorcraft/beru plugs. I believe yours will be the ZD9, 10 bux at O'reillys and there are 8 of them. Good luck and enjoy that bad boy! These are AWESOME trucks and VERY easy to keep on the road.
Old Dec 14, 2011 | 06:16 AM
fonefiddy's Avatar
fonefiddy
Air intrusion. Replace Return lines/O-Rings.
Old Dec 14, 2011 | 09:32 AM
Kingjustinf-350
Adt yes there is clicking .... It feels and sounds like its coming from the injection pump I have had a few people tell me I have air in the lines so im going to bleed them today .....
Old Dec 14, 2011 | 10:21 AM
ADTMan's Avatar
ADTMan
cool! I hope you get it figured out. I hate it when i have a truck down.
Old Dec 14, 2011 | 10:27 AM
Kingjustinf-350
Yea ... It's my rig truck .... And I Ho back out on Monday so I'm scrambling to get her running
Old Dec 17, 2011 | 08:42 PM
Kingjustinf-350
Ok so my dad came up and we replaced the transfer pump and decided that the injection pump is out .... So if anyone has a connection for a cheep one please let me know ..... Thanks for Yalls help
Old Dec 17, 2011 | 10:21 PM
greywynd's Avatar
greywynd
How did you decide that? Did you crack the lines at the injectors and bleed the air? Fuel at the schrader valve at the filter head?
