random no start .... HELP Please!!!!
Old Dec 17, 2011 | 11:33 PM
Kingjustinf-350's Avatar
Kingjustinf-350
Yes we cracked and blead .... I'm getting fuel to the pump but not enough to the injectors to keep running it fires runs a sec and dies we replaced the transfer pump the one on the block ... I was told if it starts to go out it could jack with the injector pump .... Was that wrong ?
Old Dec 17, 2011 | 11:56 PM
starmilt's Avatar
starmilt
I have never had an injector pump go bad because a fuel pump did, in fact they will usually run good enough to get you home with a bad pump.
Did you fill the filter completely, this thread started out sounding like classic air intrusion.
When you crack the injector lines are you getting any air at all of them.
Old Dec 18, 2011 | 12:16 AM
Kingjustinf-350
I had no pressure to fuel filter so I pulled pump u could tell it was bad real weak I moved it by hand replaced it ... Re blead lines ... It fires fuel from all 8 lines no air now still dies I called a Local Diesle guy here in san angelo he said he thinks its the inject pump its about 500 dollars so I'm Jus gunna replace it and see what happens ..... I love my truck but now I'm wishing it had the 429 in it
01pstroke
22
Sep 25, 2014 04:39 PM
connor_warren59
Oct 10, 2010 06:03 PM
Maze
17
May 3, 2010 09:48 PM
amubus1972
Sep 9, 2008 08:58 PM
the_oil_jockey
Dec 6, 2006 06:54 PM
