Four cylinder heater opinion- COLD WEATHER GUYS
I don't live in a severe cold weather climate, but my 2.0L Escape is much slower to heat up than my wife's 2004 Honda Element 2.3L. After the engine warms up to operating temperature, the heater blows hot, but I don't know how it would do in the Arctic. The Escape has no inside/outside air control. The Honda does. I hate the Escape's climate control. The Honda has an inside/outside air button & an A/C ON/OFF switch. The Escape 2.0L doesn't. With all of the diesel engines around, it is the pits: during Winter, either get choked by the diesel fumes & smog or freeze.
flipkos, I wouldnt pay any attention to the older 2.0 liter models as they were low cost entry model that haven't been built for years. All modern Escapes have the ability to recirculate or use outside air. I can't address your question directly because I own a 6 cylinder model but I can attest that it will roast your interior within a few miles.
I would think the heater in the 4 cyl Escape would be just as effective as the 6 cyl; this is largely based on what the thermostat opening temperature is. I'm sure the heater cores are the same size on the 4 and 6 cyl models.
George
Tempeture is a rational factor to horsepower.
Hence a hot 390 would need a bigger radiator then a low CR truck 391. Though the 391s radiator is almost always larger due to reliability being a primary concern.
No, I aint to worried but was woundering if anyone had any truly legit gripes with the 2.5 engines heater output.
We never get below zero, but we hit the teens and single digits a few times a year here in PA. I have to say, of every car I have ever owned or driven, my 06 Mariner Hybrid (4 Cyl) heats up the fastest - by far. I would say I get heat in under 3 minutes....and within 5 minutes there is plenty of it. I think the biggest issue with heat is that there's almost nothing to the doors but hollow sheetmetal so you've got to rely on constant heat since there's really no insulation.
theenforcer
03-23-2013 05:13 PM
78ford351m
01-15-2009 10:56 PM
