Sponsored by: Real Truck
Ranch Hand Grille Guard (Pic Request)
Old Dec 16, 2011 | 09:43 AM
Mud_Man_Dude's Avatar
Mud_Man_Dude
Originally Posted by XB70
Never figured out why anybody would put light mounting tabs in a location that severely restricts both the diameter and depth of the light.
It's a big-*** truck with a big-*** grill guard. Why go with small low performance lights?
The welded tabs are drilled so that a 1/2 bolt can be used.
I personally thought the lights were not low performance. Lights « Rally800 « Rally 800 130w Driving Stainless « KC HiLiTES: Auxiliary Lighting, Off Road Lights, HID Off Road Lights, Fog Lights, LED Light Bars, Driving Lights, Light Bars, Wiring Accessories, Flashlights, Torches
What driving lights do you have?
Old Dec 16, 2011 | 03:32 PM
XB70's Avatar
XB70
See my previous post. Hella Rallye 4000s. They are almost 9 inches in diameter and the tabs on your grill are too close to the vertical beams. There also isn't enough room behind the tabs for the Hella 4000s to fit. The light has too much depth.
It's not about the size of the hole in your welded tab. It's about the room around the tab. Enough for junior-sized lights with small reflectors. Again, I don't see the point when you're dealing with a huge truck and huge grill. Why run lights smaller than guys put on their Subaru WRXs?
Old Dec 16, 2011 | 04:47 PM
fullpoints79's Avatar
fullpoints79
The good news for mud man dude is his lights:
a) look great.
b) since they are smaller there is no way that vertical bar will cut into the actual beam of the light.
c)130 watts regardless of size of reflector is plenty of lighting power for normal needs. He does have headlights on his bad *** 2011 that work well
Old Dec 16, 2011 | 07:27 PM
XB70's Avatar
XB70
a) look great.
a) Opinion.
b) My installation does not interfere with the beam spread of my Hella 4000s.
c) 130w H1 bulbs are rated for 50 hours use. 100w bulbs are rated for 150 hours. 130w bulbs put out 3,000 lumins vs. 2,500 for 100w. 20% more lumins for one third the life. Sadly, those extra 500 lumins do not come close to overcoming the inefficiencies of the smaller KC reflector. A Hella 4000 with a 100w bulb throws more usable light than that KC with a 130w bulb. Of course, you could run 130w in the Hellas.
I'm sorry, but holding everything else equal is the single most important factor in determining light output. Wanna bet 55w bulbs in my Hella 4000s perform better than 130w bulbs in those KCs?
Old Jan 14, 2012 | 10:26 PM
AirborneCav's Avatar
AirborneCav
Lights...
I own both 130watt KCs on a Jeep and 100watt Hella 4000s (with citylights) on my Super Duty. I believe that the KC's throw better light. However, the Hellas are was cool!
I would like to know if anyone has converted the Hella lights to HID?
I had to create a special bar to mount the Hella's on my Ranchhand. However, I like the mounting on the side of the pillars!
crisman
Mar 2, 2018 10:04 PM
jade97
2009 - 2014 F150
18
May 20, 2011 01:38 PM
BigNiner19
2004 - 2008 F150
Sep 1, 2008 11:03 PM
AF Mezkin
Jan 13, 2006 11:38 AM
jetjock16
Jan 30, 2005 09:38 PM
