ok so i know have a issue up top with fuel leaking from somewhere..quick history just rebuilt fuel bowl and changed fuel pump.. new banjo bolt gaskets.. i can not find the leak anywhere everything i can see that i played with is dry.. i have 3 puddles in the low spots, including under the banjo bolt which i know isn't leaking... but what confuses me is after i soaked everything up in the valley within a matter of seconds i have fuel dripping down right above my clutch master cylinder.. before the valley is even wet anywhere it could be coming from on the back of the engine? from what i can gather there is no reason it should come from where it is... i gave a good clean to the fuel line that goes to the drivers side head....and can't see the leak anywhere there?? any help is greatly appreciated... Thanks again guys!!
