GVW
Old Dec 12, 2011 | 02:02 AM
jumbofordman's Avatar
jumbofordman
Originally Posted by danr1
Yea as stated no hub sticking out would be semi floater. Truck is has no more load capacity/capability then the one you have now.
While the axle may be a semi-floater, it has a bigger ring and pinion and bigger shafts, which do increase capacity. Plus the 250 will have bigger brakes which make carrying a bigger load safer. Lastly, the springs will be stiffer so the rear end will sag a lot less.
Old Dec 12, 2011 | 10:08 AM
Phy's Avatar
Phy
The axle load ratings are on the door jamb sticker, if that's still on the truck...
Buickman85
Apr 19, 2016 02:11 AM
musicars
Sep 30, 2015 04:03 PM
bigteal
Feb 18, 2013 12:18 PM
nanuke1
Sep 27, 2003 08:59 PM
tendicott
May 21, 2000 05:24 AM
