LMC headlight harness
Old Jan 25, 2012 | 02:55 AM
  #31
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The LMC kit is quite enough for me, and anyone headed down the road towards me.
I like the fact that Ryan went the extra mile with his kit.
But I don't have the money for something that I'm not going to use to its potential.
Old Jan 25, 2012 | 05:12 AM
  #32
Diesel_Brad's Avatar
Diesel_Brad
Originally Posted by Thumper19
I have 4000k HIDs and they came with a new harness to pull power directly from the battery. They work amazingly well and are bright as the sun... white light that is. The new harness was very simple to do and the ballasts are tiny. Paid 75$ for it all and lifetime replacements on the bulbs.
Yes but you are blinding EVERYONE in the process. The stock housing do NOT hve the correct reflector for HID bulbs
Old Jan 25, 2012 | 06:52 AM
  #33
TexasGuy001's Avatar
TexasGuy001
I doubt the headlight housings will handle over wattage bulbs. Besides, they are illegal for a reason.
As for the HID retrofit, that is just not a good idea. It may be brighter, but will produce excessive glare to oncoming drivers. The optics are designed for halogen not HID.
This is just my opinion. I hate driving towards any car with HID even factory equipped.
Old Jan 25, 2012 | 07:21 AM
  #34
Scndsin's Avatar
Scndsin
Just for some clarification, these harness kits consist of 2 relays one for each HL, that the stock harness & stock HL switch energizes to feed heavier wiring directly from the battery to bulbs.
If so, I get the gauge of wiring from above, but what are the relays rated?
Old Jan 25, 2012 | 07:30 AM
  #35
TexasGuy001
There is one relay for low and one relay for high. The bulbs share each relay. The relays are 30-40 amp.
Old Jan 25, 2012 | 08:08 AM
  #36
Scndsin's Avatar
Scndsin
Ah yeah, thanx, didn't think of it that way. I got it in my head now. I've got plenty of wire & pieces/parts so I'll nab some relays & have a project for a rainy day.
(On edit, 3K posts today... WOHOO! )
Old Jan 25, 2012 | 08:10 AM
  #37
Midnite1987's Avatar
Midnite1987
Here's a good write up on it
https://www.ford-trucks.com/article/...r_Brights.html
Old Jan 25, 2012 | 10:32 AM
  #38
Thumper19's Avatar
Thumper19
Actually talk to a hid designer. They are capable for regular housings as well. 9 times out of 10 its people don't know how to aim they're lights right. I've had mine for years with no problems. Hid housings are just projector lens because most won't know/do the adjustments needed to correct the lens
Old Jan 25, 2012 | 11:38 AM
  #39
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
HID's behind a faceted lens???
More than a hack job, and annoying, a danger to others on the road...
Whiter Whites, Brighter Brights .: Articles
I see in that writeup he mentions two #87 terminals.
Don't make the mistake of confusing 87 & 87A (which is NC, and open when the relay is energized)
This is how a 'Bosch' relay is pinned out.
Old Jan 25, 2012 | 11:53 AM
  #40
86F150302's Avatar
86F150302
Not true. HIDs in halogen headlights cause glare no matter how they are aimed.
If you are going to run HIDs you need to do a projector retrofit.
Old Jan 25, 2012 | 08:47 PM
  #41
TexasGuy001
What 86F150302 said.
Old Jan 25, 2012 | 09:13 PM
  #42
Midnite1987
You can get relays with a single #87 or #87,#87a or #87,#87. Just have to make sure you et the ones with the 2 #87 terminals. Not the one with the #87a
Old Jan 25, 2012 | 09:19 PM
  #43
Midnite1987
Need these ones from Bosch they have the 2 #87 terminals
http://rb-aa.bosch.com/boaarocs/inde...30&prod_id=121
Old Jan 25, 2012 | 09:47 PM
  #44
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Relay online catalog
I didn't mean to argue.
The "classic" Bosch layout includes 87 & 87A terminals.
People talk of "Bosch" relays regardless of manufacturer.
Just a 'heads up' to be aware of.
Old Jan 25, 2012 | 10:55 PM
  #45
xxshine's Avatar
xxshine
But why does the 87 and 87a matter ? The relays that i installed have 85 - 86 - 87 with 85 being the ground and 87 being power from battery.
