LMC headlight harness
Old Dec 24, 2011 | 06:17 PM
White 97 xlt's Avatar
White 97 xlt
Right.. The harness is female, the bulb and your upgrade harness are male..
The harness plugs into the harness the same as a headlight bulb.
Old Dec 24, 2011 | 06:21 PM
91dirtydiesel's Avatar
91dirtydiesel
Ok I think I got it now, thanks!
Old Dec 24, 2011 | 06:27 PM
danr1's Avatar
danr1
Originally Posted by 91dirtydiesel
The headlight plugs on the harness are female. The plug that I'm talking about is male ... Are we on the same page with what one were talking about?
Exactly, you'd pull the headlight out of the trucks harness connector then plug in your pictured add on harness into that same connector you just unplugged the headlight from.
That is why that one connector is male so it will plug in where the head light plugged in.
Old Jan 23, 2012 | 11:11 AM
Diesel_Brad's Avatar
Diesel_Brad
I just wanted to post my results with the RJM harness
Stock
Upgraded harness
Old Jan 23, 2012 | 11:34 AM
Edgethis's Avatar
Edgethis
Wow that is good. I can't wait to get mine installed!
Old Jan 24, 2012 | 12:23 AM
892504x4's Avatar
892504x4
OK this is has now been moved to the top of my to-do list!!!
Old Jan 24, 2012 | 12:47 AM
Midnite1987's Avatar
Midnite1987
Wow... What guage wire is the harness?
Old Jan 24, 2012 | 10:26 AM
TexasGuy001's Avatar
TexasGuy001
That's about the same as the improvement I saw on mine.
Old Jan 24, 2012 | 11:13 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Everyone likes a relay harness.
It makes things much easier on the dashboard harness too...
Old Jan 24, 2012 | 05:11 PM
Diesel_Brad
I dont know the gauge of the wire but it is MUCH larger than the LMC one
Old Jan 24, 2012 | 10:01 PM
TexasGuy001
The RJM wiring is defintely heavier gauge than the LMC one. It is more expensive though. The LMC one is better than not having one at all.
Old Jan 24, 2012 | 10:14 PM
Midnite1987
RJM harness
Large 12G wire.
Will easily power 130 watt bulbs or larger.
Will our headlights handle a 130 watt bulb without melting? Lol
Old Jan 24, 2012 | 10:47 PM
  #28
Thumper19's Avatar
Thumper19
I have 4000k HIDs and they came with a new harness to pull power directly from the battery. They work amazingly well and are bright as the sun... white light that is. The new harness was very simple to do and the ballasts are tiny. Paid 75$ for it all and lifetime replacements on the bulbs.
Old Jan 24, 2012 | 10:52 PM
  #29
Midnite1987
Where did you find those?
Old Jan 24, 2012 | 10:53 PM
  #30
Thumper19's Avatar
Thumper19
The price of the harness and 80w bulbs would be close to the price of a full hid kit. Not to mention higher wattage filament bulbs have maybe a year life span.
