AOD shift problems
Old Dec 11, 2011 | 02:59 PM
302flareside1992's Avatar
302flareside1992
AOD shift problems
My buddy just picked up a 89 f150 with an AOD truck and i dont know anything about transmissions and he is asking me for help, so i came to yall.
His truck is dropping into neutral between gears when accelerating. Between 1st and 2nd. And then again when it is trying to switch into overdrive. You can get it switch back into gear by hitting the overdrive button when that happens. Most of the time that takes care of it but sometimes it will fall right back into neutral when you hit the button again to turn the overdrive back on.
The fluid was a little low when he got it. And when we put more in there the old fluid looked old and burnt up. Adding more fluid didnt really help the problem at all.
Since I dont really know anything about trannys I told him to start by replacing all the fluids and filters and see where that takes him.
Any advice is appreciated.
Old Dec 11, 2011 | 03:22 PM
Lazy K's Avatar
Lazy K
Fuel Injection Technical Library » How To Run a Self-Test Here is a link on how to check for trouble codes, would be a good first step.
If he has an OD button he does not have an AOD trans but has an E4OD. It could well be a bad transmission range sensor (TRS), might be worth replacing the existing one with an updated one (some parts stores list it as a Neutral safety switch). However see if any codes first.
fatfenders56
Jul 9, 2015 07:59 AM
garagegods
Jul 5, 2015 08:16 PM
sinnerman21
1978 - 1996 Big Bronco
Apr 21, 2009 02:33 PM
nx_1701_d
Apr 19, 2006 01:47 PM
barry71
Jul 20, 2005 11:52 AM
