aod dead
Old Jul 18, 2005 | 06:46 PM
barry71's Avatar
barry71
aod dead
ok my aod is bad big suprise a little help in determing my problem my '89 f-150 wil shift fine through the first three gears but when it goes into overdrive nothing its like its in nuetral whats the problem?
Old Jul 18, 2005 | 08:12 PM
220k-f-150's Avatar
220k-f-150
My experience with AOD. First the OD, then 3rd, then rebuild if you plan to drive it at highway speeds. Doesn't sound good.
Good luck!
Old Jul 20, 2005 | 11:52 AM
Shadowe's Avatar
Shadowe
Optimistic Diagnosis. Could be low fluid, or clogged valves... You could do a Tranny Flush and fill to see if it helps. I will warn you though, 9 times out of 10 when it's a fluid problem, the tranny will simply not shift into OD, and you will be stuck in a lower gear.
David
Want a Free IPOD?
http://www.freeiPods.com/?r=9181869
